Datasheet ADG333A (Analog Devices) - 10 Manufacturer Analog Devices Description Quad SPDT Switch Pages / Page 13 / 10 — Data Sheet. ADG333A. TEST CIRCUITS. IDS. IS (OFF). ID (ON). NC = NO … Revision B File Format / Size PDF / 246 Kb Document Language English
Data Sheet. ADG333A. TEST CIRCUITS. IDS. IS (OFF). ID (ON). NC = NO CONNECT. RON = V1/IDS. VDD. 0.1. +3V. –10V. 50%. VOUT. +10V. 300. 35pF. tOFF. GND. VSS. tON
Model Line for this Datasheet Text Version of Document Data Sheet ADG333A TEST CIRCUITS IDS IS (OFF) ID (ON) A NC A V1 S D S D V V S D VD 01212-015NC = NO CONNECT 01212-016S D VD RON = V1/IDS 01212-014 Figure 14. On Resistance Figure 15. Off Leakage Figure 16. On LeakageVDD 0.1 µF +3V VDD –10V 50% 50% V SB IN D 0V VS VOUT SA RL CL +10V 300 Ω35pF +10V IN tOFF VS 0V GND VSS 50% 50% tON –10V 0.1 µF VSS 01212-017 Figure 17. Switching TimesVDD 0.1 µF 3V VDD V VIN S SB D V 0V OUT SA RL CL 300 Ω35pF V IN S V 50% 50% OUT GND VSS tOPEN 0.1 µF VSS 01212-018 Figure 18. Break-Before-Make Delay, tOPENVDD VDD 3V RD VIN V V OUT D D SA C 0V L IN 10nF VOUT Q × ∆V ∆V GND V INJ = CL OUT OUT SS 0V 01212-019VSS Figure 19. Charge InjectionVDD VDD 0.1 µF 0.1 µF VDD VDD 75 ΩVOUT S D S D RL 75 ΩVIN V V IN1 V S IN2 GND VSS VS S D 0.1 µF VOUT NC V R SS 01212-020L GND V 75 ΩSS CHANNEL-TO-CHANNEL 0.1 µF CROSSTALK V 20 ×LOG |V SS S/VOUT| 01212-021 Figure 20. Off Isolation Figure 21. Channel-to-Channel Crosstalk Rev. B | Page 10 of 13 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION TERMINOLOGY PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS APPLICATIONS INFORMATION ADG333A SUPPLY VOLTAGES POWER SUPPLY SEQUENCING OUTLINE DIMENSIONS ORDERING GUIDE
