Datasheet ADG5421F (Analog Devices) - 6
Description±60 V Fault Protection and Detection, 11 Ω RON, Dual SPST Switch
Pages / Page31 / 6 — ADG5421F. Data Sheet. Parameter. +25°C. −40°C to +85°C. −40°C to +125°C. …
File Format / SizePDF / 594 Kb
ADG5421F. Data Sheet. Parameter. +25°C. −40°C to +85°C. −40°C to +125°C. Unit. Test Conditions/Comments
ADG5421F Data Sheet Parameter +25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
link to page 21 link to page 21 link to page 21 link to page 19 link to page 21 link to page 21 link to page 21 link to page 21 link to page 21 link to page 24 link to page 24
LEAKAGE CURRENTS VDD = +22 V, VSS = −22 V IS (Off) ±0.05 nA typ VS = ±15 V, VD =  15 V, see Figure 32 ±0.2 ±2.5 ±22 nA max VS = ±15 V, VD =  15 V ±8 nA max VS = ±15 V, VD =  15 V, −40°C to +105°C ID (Off) ±0.05 nA typ VS = ±15 V, VD =  15 V, see Figure 32 ±0.2 ±2.5 ±22 nA max VS = ±15 V, VD =  15 V ±8 nA max VS = ±15 V, VD =  15 V, −40°C to +105°C ID (On), IS (On) ±0.05 nA typ VS = ±15 V, VD = ±15 V, see Figure 33 ±0.3 ±3.5 ±30 nA max VS = ±15 V, VD = ±15 V ±14 nA max VS = ±15 V, VD = ±15 V, −40°C to +105°C FAULT VT 0.7 V typ See Figure 25 IS With Overvoltage ±30 µA typ VDD = +22 V, VSS = −22 V, GND = 0 V, VS = ±60 V, see Figure 34 Power Supplies Grounded or ±5.5 µA typ VDD = 0 V or floating, VSS = 0 V or Floating floating, GND = 0 V, IN = 0 V or floating, VS = ±60 V, see Figure 35 ID With Overvoltage ±0.1 nA typ VDD = +22 V, VSS = −22 V, GND = 0 V, VS = ±60 V, see Figure 34 ±0.2 ±2 ±20 nA max VDD = +22 V, VSS = −22 V, GND = 0 V, VS = ±60 V Power Supplies Grounded ±0.1 nA typ VDD = 0 V, VSS = 0 V, GND = 0 V, VS = ±60 V, IN = 0 V, see Figure 35 ±0.2 ±2 ±20 nA max VDD = 0 V, VSS = 0 V, GND = 0 V, VS = ±60 V, IN = 0 V Power Supplies Floating ±0.1 µA typ VDD = floating, VSS = floating, GND = 0 V, VS = ±60 V, IN = 0 V, see Figure 35 DIGITAL INPUTS AND OUTPUTS VINH 1.3 V min VINL 0.8 V max IINL or IINH 0.7 µA typ VIN = 0 V or 5 V 1 µA max VIN = 0 V or 5 V CIN 5 pF typ VOL 0.4 V max IFF = 2 mA DYNAMIC CHARACTERISTICS tON 12.6 µs typ RL = 300 Ω, CL = 35 pF, VS = 10 V, see Figure 45 15.9 15.9 15.9 µs max RL = 300 Ω, CL = 35 pF, VS = 10 V tOFF 140 ns typ RL = 300 Ω, CL = 35 pF, VS = 10 V, see Figure 45 160 160 160 ns max RL = 300 Ω, CL = 35 pF, VS = 10 V tD 11.5 µs typ RL = 300 Ω, CL = 35 pF, VS = 10 V 8.9 8.8 8.8 µs min RL = 300 Ω, CL = 35 pF, VS = 10 V Rev. 0 | Page 6 of 31 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM COMPANION PRODUCTS PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ELECTROSTATIC DISCHARGE (ESD) RATINGS ESD Ratings for ADG5421F ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION SWITCH ARCHITECTURE ESD Performance Trench Isolation OVERVOLTAGE FAULT PROTECTION Power-On Protection Power-Off Protection Overvoltage Interrupt Flag APPLICATIONS INFORMATION POWER SUPPLY RAILS POWER SUPPLY RECOMMENDATIONS POWER SUPPLY SEQUENCING PROTECTION SIGNAL RANGE INTELLIGENT FAULT DETECTION SWITCH IN A KNOWN STATE HIGH VOLTAGE SURGE SUPPRESSION RELATED PRODUCTS OUTLINE DIMENSIONS ORDERING GUIDE
