Datasheet ADG5404F (Analog Devices)
DescriptionFault Protection and Detection, 10 Ω RON, 4-Channel Multiplexer
Pages / Page30 / 1 — Fault Protection and Detection,. 10 Ω R. ON, 4-Channel Multiplexer. Data …
RevisionC
File Format / SizePDF / 652 Kb
Fault Protection and Detection,. 10 Ω R. ON, 4-Channel Multiplexer. Data Sheet. ADG5404F. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet ADG5404F Analog Devices, Revision: C
link to page 13
Fault Protection and Detection, 10 Ω R ON, 4-Channel Multiplexer Data Sheet ADG5404F FEATURES FUNCTIONAL BLOCK DIAGRAM Overvoltage protection up to −55 V and +55 V ADG5404F Power-off protection up to −55 V and +55 V S1 Overvoltage detection on source pins S2 Interrupt flags indicate fault status D S3 Low on resistance: 10 Ω (typical) S4 On-resistance flatness of 0.5 Ω (maximum) 4 kV human body model (HBM) ESD rating FAULT DETECTION FF Latch-up immune under any circumstance + SWITCH SF DRIVER Known state without digital inputs present
001
VSS to VDD analog signal range A0/F0 A1/F1 EN DR
12856-
±5 V to ±22 V dual supply operation
Figure 1.
8 V to 44 V single-supply operation Fully specified at ±15 V, ±20 V, 12 V, and 36 V APPLICATIONS Analog input/output modules Process control/distributed control systems Data acquisition Instrumentation Avionics Automatic test equipment Communication systems Relay replacement GENERAL DESCRIPTION
The ADG5404F is an analog multiplexer composed of four The low on resistance of the ADG5404F, combined with on- single channels with fault protected inputs. The ADG5404F resistance flatness over a significant portion of the signal range, switches one of the four inputs to a common drain, D, as makes it an ideal solution for data acquisition and gain determined by the 2-bit binary address lines (A0 and A1). An switching applications where excellent linearity and low enable digital input, EN, is used to disable all the switches. Each distortion are critical. channel conducts equally wel in both directions when on, and Note that, throughout this data sheet, the dual function pin names each switch has an input signal range that extends to the are referenced only by the relevant function where applicable. See supplies. The digital inputs are compatible with 3 V logic inputs the Pin Configurations and Function Descriptions for ful pin over the full operating supply range. names and function descriptions. When no power supplies are present, the switch remains in the off
PRODUCT HIGHLIGHTS
condition, and the channel inputs are high impedance. Under normal operating conditions, if the analog input signal levels on 1. Source pins are protected against voltages greater than the any Sx pin exceed V supply rails, up to −55 V and +55 V. DD or VSS by a threshold voltage, VT, the channel turns off and that Sx pin becomes high impedance. If 2. Source pins are protected against voltages between −55 V the channel is on, the drain pin reacts according to the drain and +55 V in an unpowered state. response (DR) input pin. If the DR pin is left floating or pulled 3. Overvoltage detection with digital output indicates high, the drain remains high impedance and floats. If the DR pin operating state of switches. is pulled low, the drain pul s to the exceeded rail. Input signal 4. Trench isolation guards against latch-up. levels up to +55 V or −55 V relative to ground are blocked, in 5. Optimized for low on resistance and on-resistance flatness. both the powered and unpowered conditions. 6. The ADG5404F operates from a dual supply of ±5 V up to ±22 V, or a single power supply of 8 V up to 44 V.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2014–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION SWITCH ARCHITECTURE ESD Performance Trench Isolation FAULT PROTECTION Power-On Protection Power-Off Protection Digital Input Protection Overvoltage Interrupt Flag APPLICATIONS INFORMATION POWER SUPPLY RAILS POWER SUPPLY SEQUENCING PROTECTION SIGNAL RANGE LOW IMPEDANCE CHANNEL PROTECTION POWER SUPPLY RECOMMENDATIONS HIGH VOLTAGE SURGE SUPPRESSION INTELLIGENT FAULT DETECTION LARGE VOLTAGE, HIGH FREQUENCY SIGNALS OUTLINE DIMENSIONS ORDERING GUIDE
