Datasheet ADG5233, ADG5234 (Analog Devices) - 5
DescriptionHigh Voltage Latch-Up Proof, Triple/Quad SPDT Switches
Pages / Page22 / 5 — Data Sheet. ADG5233/ADG5234. Parameter. 25°C. −40°C to +85°C. −40°C to …
RevisionD
File Format / SizePDF / 478 Kb
Data Sheet. ADG5233/ADG5234. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C. Unit. Test Conditions/Comments. 12 V SINGLE SUPPLY
Data Sheet ADG5233/ADG5234 Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments 12 V SINGLE SUPPLY
link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16
Channel-to-Channel Crosstalk −87 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 29 −3 dB Bandwidth 370 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 32 Insertion Loss −5.6 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 32 CS (Off ) 2.8 pF typ VS = 0 V, f = 1 MHz CD (Off ) 9 pF typ VS = 0 V, f = 1 MHz CD (On), CS (On) 13 pF typ VS = 0 V, f = 1 MHz POWER REQUIREMENTS VDD = +22 V, VSS = −22 V IDD 50 μA typ Digital inputs = 0 V or VDD 70 110 μA max ISS 0.001 μA typ Digital inputs = 0 V or VDD 1 μA max VDD/VSS ±9/±22 V min/V max GND = 0 V 1 Guaranteed by design; not subject to production test.
12 V SINGLE SUPPLY
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 3. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance, RON 360 Ω typ VS = 0 V to 10 V, IS = −1 mA; see Figure 28 500 610 700 Ω max VDD = 10.8 V, VSS = 0 V On-Resistance Match Between 5.5 Ω typ VS = 0 V to 10 V, IS = −1 mA Channels, ∆RON 20 21 22 Ω max On-Resistance Flatness, RFLAT (ON) 170 Ω typ VS = 0 V to 10 V, IS = −1 mA 280 335 370 Ω max LEAKAGE CURRENTS VDD = 13.2 V, VSS = 0 V Source Off Leakage, IS (Off ) ±0.02 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 30 ±0.1 ±0.2 ±0.4 nA max Drain Off Leakage, ID (Off ) ±0.02 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 30 ±0.1 ±0.2 ±0.4 nA max Channel On Leakage, ID (On), IS (On) ±0.08 nA typ VS = VD = 1 V/10 V; see Figure 26 ±0.2 ±0.3 ±0.9 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 μA typ VIN = VGND or VDD ±0.1 μA max Digital Input Capacitance, CIN 3 pF typ Rev. D | Page 5 of 22 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Table of Contents Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide
