Datasheet ADG5233, ADG5234 (Analog Devices) - 9
DescriptionHigh Voltage Latch-Up Proof, Triple/Quad SPDT Switches
Pages / Page22 / 9 — Data Sheet. ADG5233/ADG5234. ABSOLUTE MAXIMUM RATINGS. Table 7. Parameter …
RevisionD
File Format / SizePDF / 478 Kb
Data Sheet. ADG5233/ADG5234. ABSOLUTE MAXIMUM RATINGS. Table 7. Parameter Rating. ESD CAUTION
Data Sheet ADG5233/ADG5234 ABSOLUTE MAXIMUM RATINGS Table 7 Parameter Rating ESD CAUTION
link to page 7 link to page 8
TA = 25°C, unless otherwise noted.
Table 7.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a V stress rating only; functional operation of the product at these DD to VSS 48 V V or any other conditions above those indicated in the operational DD to GND −0.3 V to +48 V V section of this specification is not implied. Operation beyond SS to GND +0.3 V to −48 V Analog Inputs1 V the maximum operating conditions for extended periods may SS − 0.3 V to VDD + 0.3 V or 30 mA, whichever occurs affect product reliability. first Only one absolute maximum rating can be applied at any Digital Inputs1 VSS − 0.3 V to VDD + 0.3 V or 30 mA, whichever occurs one time. first
ESD CAUTION
Peak Current, Sx or Dx Pins ADG5233 76 mA (pulsed at 1 ms, 10% duty cycle maximum) ADG5234 67 mA (pulsed at 1 ms, 10% duty cycle maximum) Continuous Current, Sx or Dx2 Data + 15% Temperature Range Operating −40°C to +125°C Storage −65°C to +150°C Junction Temperature 150°C Thermal Impedance, θJA 16-Lead TSSOP (4-Layer Board) 112.6°C/W 20-Lead TSSOP (4-Layer Board) 143°C/W 16-Lead LFCSP (4-Layer Board) 30.4°C/W 20-Lead LFCSP (4-Layer Board) 30.4°C/W Reflow Soldering Peak 260(+0/−5)°C Temperature, Pb Free Human Body Model (HBM) ESD Input/Output Port to Supplies 8 kV Input/Output Port to 2 kV Input/Output Port All Other Pins 8 kV 1 Overvoltages at the INx, Sx, and Dx pins are clamped by internal diodes. Limit current to the maximum ratings given. 2 See Table 5 and Table 6. Rev. D | Page 9 of 22 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Table of Contents Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide
