Datasheet ADG1401, ADG1402 (Analog Devices)
Description | 1 Ω On Resistance, ±15 V/+12 V/±5 V, iCMOS SPST Switches |
Pages / Page | 16 / 1 — 1 Ω On Resistance, ±15 V/+12 V/±5 V. CMOS SPST Switches. ADG1401/ADG1402. … |
File Format / Size | PDF / 451 Kb |
1 Ω On Resistance, ±15 V/+12 V/±5 V. CMOS SPST Switches. ADG1401/ADG1402. FEATURES. FUNCTIONAL BLOCK DIAGRAM. 1 Ω on resistance
link to page 1
i
CMOS SPST Switches ADG1401/ADG1402 FEATURES FUNCTIONAL BLOCK DIAGRAM 1 Ω on resistance ADG1401 0.2 Ω on resistance flatness S D Up to 430 mA continuous current Fully specified at +12 V, ±15 V, ±5 V No VL supply required 3 V logic-compatible inputs IN Rail-to-rail operation
01
8-lead MSOP and 8-lead, 3 mm × 2 mm LFCSP packages
0 6-
SWITCHES SHOWN FOR A LOGIC 1 INPUT
48 08 Figure 1. ADG1401 Functional Block Diagram
APPLICATIONS Automatic test equipment Data acquisition systems ADG1402 Battery-powered systems S D Sample-and-hold systems Audio signal routing Video signal routing IN Communication systems Relay replacements
2 0 0 6-
48 08 Figure 2. ADG1402 Functional Block Diagram
GENERAL DESCRIPTION
The ADG1401/ADG1402 contain a single-pole/single-throw The on resistance profile is very flat over the full analog input (SPST) switch. Figure 1 shows that with a logic input of 1, the range ensuring excellent linearity and low distortion when switch of the ADG1401 is closed and that of the ADG1402 is switching audio signals. The iCMOS construction ensures open. Each switch conducts equally well in both directions when ultralow power dissipation, making the part ideally suited for on and has an input signal range that extends to the supplies. In portable and battery-powered instruments. the off condition, signal levels up to the supplies are blocked.
PRODUCT HIGHLIGHTS
The iCMOS® (industrial CMOS) modular manufacturing process 1. 1.3 Ω maximum on resistance at 25°C. combines high voltage, complementary metal-oxide semiconductor 2. Minimum distortion. (CMOS) and bipolar technologies. It enables the development 3. 3 V logic-compatible digital inputs: VINH = 2.0 V, VINL = 0.8 V. of a wide range of high performance analog ICs capable of 33 V 4. No VL logic power supply required. operation in a footprint that no other generation of high voltage 5. 8-lead MSOP and 8-lead, 3 mm × 2 mm LFCSP packages. parts has achieved. Unlike analog ICs using conventional CMOS processes, iCMOS components can tolerate high supply voltages while providing increased performance, dramatically lower power consumption, and a reduced package size.
Rev. 0 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2009 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY +12 V SINGLE SUPPLY ±5 V DUAL SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
