Datasheet ADG1608, ADG1609 (Analog Devices) - 8
Description4.5 Ω RON, 8-Channel ±5 V,+12 V, +5 V, and +3.3 V Multiplexer
Pages / Page20 / 8 — ADG1608/ADG1609. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 7. Parameter …
RevisionA
File Format / SizePDF / 480 Kb
ADG1608/ADG1609. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 7. Parameter Rating. ESD CAUTION
ADG1608/ADG1609 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 7 Parameter Rating ESD CAUTION
link to page 7 link to page 7
TA = 25°C, unless otherwise noted. Stresses at or above those listed under Absolute Maximum
Table 7.
Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these
Parameter Rating
or any other conditions above those indicated in the operational VDD to VSS 18 V section of this specification is not implied. Operation beyond VDD to GND −0.3 V to +18 V the maximum operating conditions for extended periods may VSS to GND +0.3 V to −18 V affect product reliability. Analog Inputs1 VSS − 0.3 V to VDD + 0.3 V or 30 mA, whichever occurs first
ESD CAUTION
Digital Inputs1 GND − 0.3 V to VDD + 0.3 V or 30 mA, whichever occurs first Peak Current, S or D 710 mA (pulsed at 1 ms, 10% duty cycle maximum) Continuous Current, S or D2 Data + 15% Operating Temperature Range Industrial −40°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C 16-Lead TSSOP, θJA Thermal 112.6°C/W Impedance, 0 Airflow (4-Layer Board) 16-Lead LFCSP, θJA Thermal 48.7°C/W Impedance, 0 Airflow (4-Layer Board) Reflow Soldering Peak 260°C Temperature, Pb-free 1 Overvoltages at IN, S, or D are clamped by internal diodes. Current should be limited to the maximum ratings given. 2 See Table 5 and Table 6. Rev. A | Page 8 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
