Datasheet ADG1436 (Analog Devices) - 7
Description1.5 Ω On Resistance, ±15 V/12 V/±5 V, iCMOS, Dual SPDT Switch
Pages / Page16 / 7 — Data Sheet. ADG1436. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameter. …
File Format / SizePDF / 504 Kb
Data Sheet. ADG1436. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameter. Ratings. ESD CAUTION
Data Sheet ADG1436 ABSOLUTE MAXIMUM RATINGS Table 5 Parameter Ratings ESD CAUTION
link to page 6
TA = 25°C, unless otherwise noted. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a
Table 5.
stress rating only; functional operation of the product at these
Parameter Ratings
or any other conditions above those indicated in the operational VDD to VSS 35 V section of this specification is not implied. Operation beyond VDD to GND −0.3 V to +25 V the maximum operating conditions for extended periods may VSS to GND +0.3 V to −25 V affect product reliability. Analog Inputs1 VSS − 0.3 V to VDD + 0.3 V or 30 mA, whichever occurs first
ESD CAUTION
Digital Inputs1 GND − 0.3 V to VDD + 0.3 V or 30 mA, whichever occurs first Peak Current, S or D 600 mA (pulsed at 1 ms, 10% duty cycle maximum) Continuous Current per Data + 15% Channel, S or D2 Operating Temperature Range Automotive (Y Version) −40°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C 16-Lead TSSOP, θJA Thermal 112°C/W Impedance (4-Layer Board) 16-Lead LFCSP, θJA Thermal 30.4°C/W Impedance Reflow Soldering Peak 260(+0/−5)°C Temperature, Pb Free 1 Over voltages at IN, S, and D are clamped by internal diodes. Current must be limited to the maximum ratings given. 2 See data given in Table 4. Rev. B | Page 7 of 16 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications 15 V Dual Supply 12 V Single Supply 5 V Dual Supply Continuous Current per Channel Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Table For Switches Typical Performance Characteristics Terminology Test Circuits Outline Dimensions Ordering Guide
