Datasheet ADG1236 (Analog Devices) - 7
DescriptionLow Capacitance, Low Charge Injection, ±15 V/12 V iCMOS, Dual SPDT Switch
Pages / Page16 / 7 — Data Sheet. ADG1236. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. A 1. …
File Format / SizePDF / 351 Kb
Data Sheet. ADG1236. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. A 1. IN1. 16 NC. S1A. 15 NC. D1 1. 9 VDD. 14 NC. S1B 2. 8 S2B. TOP VIEW. S1B. 13 V
Data Sheet ADG1236 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS A 1 IN1 16 NC S1A 15 NC D1 1 9 VDD 14 NC S1B 2 8 S2B TOP VIEW S1B 13 V
Data Sheet ADG1236 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS A 1 1 C S NI N 2 1 0 1 1 1 IN1 1 16 NC S1A 2 15 NC D1 1 9 VDD ADG1236 D1 3 14 NC S1B 2 8 S2B TOP VIEW S1B 4 ADG1236 13 V (Not to Scale) DD V 3 7 D2 TOP VIEW SS VSS 5 12 S2B (Not to Scale) GND 6 11 D2 4 5 6 D 2 A NC 7 10 S2A N NI 2 G S NC 8 9 IN2 NOTES 1. NC = NO CONNECT. DO NOT CONNECT
2
TO THIS PIN.
00 03 6-
NC = NO CONNECT. DO NOT CONNECT 2. THE EXPOSED PAD MUST BE TIED
0 76- 477
TO THIS PIN. TO SUBSTRATE, V
0
SS.
047 Figure 2. TSSOP Pin Configuration Figure 3. LFCSP Pin Configuration
Table 5. Pin Function Descriptions Pin No. TSSOP LFCSP Mnemonic Description
1 11 IN1 Logic Control Input. 2 12 S1A Source Terminal. Can be an input or output. 3 1 D1 Drain Terminal. Can be an input or output. 4 2 S1B Source Terminal. Can be an input or output. 5 3 VSS Most Negative Power Supply Potential. 6 4 GND Ground (0 V) Reference. 7, 8, 14 to 16 10 NC No Connect. 9 5 IN2 Logic Control Input. 10 6 S2A Source Terminal. Can be an input or output. 11 7 D2 Drain Terminal. Can be an input or output. 12 8 S2B Source Terminal. Can be an input or output. 13 9 VDD Most Positive Power Supply Potential. Rev. A | Page 7 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION TRUTH TABLE FOR SWITCHES PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
