Datasheet ADG1311, ADG1312, ADG1313 (Analog Devices) - 4
Description±15 V/12 V Quad SPST Switches
Pages / Page12 / 4 — ADG1311/ADG1312/ADG1313. SINGLE SUPPLY. Table 2. Y. Version1. Parameter. …
File Format / SizePDF / 280 Kb
ADG1311/ADG1312/ADG1313. SINGLE SUPPLY. Table 2. Y. Version1. Parameter. 25°C. −40°C to +105°C. Unit. Test Conditions/Comments
ADG1311/ADG1312/ADG1313 SINGLE SUPPLY Table 2 Y Version1 Parameter 25°C −40°C to +105°C Unit Test Conditions/Comments
link to page 4 link to page 10 link to page 10 link to page 10 link to page 10 link to page 4 link to page 10 link to page 10 link to page 10 link to page 10 link to page 11 link to page 11 link to page 11
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 2. Y Version1 Parameter 25°C −40°C to +105°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance (RON) 325 520 Ω typ VS = 0 V − 10 V, IS = −1 mA; see Figure 10 500 Ω max VDD = 10.8 V, VSS = 0 V On Resistance Match Between 10 Ω typ VS = 0 V − 10 V, IS = −1 mA Channels (∆RON) 15 Ω max On Resistance Flatness (RFLAT(ON)) 65 Ω typ VS = 3 V/6 V/9 V, IS = −1 mA LEAKAGE CURRENTS VDD = 13.2 V, VSS = 0 V Source Off Leakage, IS (Off ) ±10 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 11 Drain Off Leakage, ID (Off ) ±10 nA typ VS = 1 V/10 V, VD = 10 V/1 V see Figure 11 Channel On Leakage, ID, IS (On) ±10 nA typ VS = VD = 1 V or 10 V; se e Figure 12 DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.001 μA typ VIN = VINL or VINH ±0.1 μA max Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS2 tON 120 ns typ RL = 300 Ω, CL = 35 pF 155 210 ns max VS = 8 V; see Figure 13 tOFF 45 ns typ RL = 300 Ω, CL = 35 pF 65 80 ns max VS = 8 V; see Figure 13 Break-Before-Make Time Delay, tD 50 ns typ RL = 300 Ω, CL = 35 pF (ADG1313 Only) 10 ns min VS1 = VS2 = 8 V; see Figure 14 Charge Injection 2 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF; see Figure 15 Off Isolation 80 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 16 Channel-to-Channel Crosstalk 90 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 17 −3 dB Bandwidth 500 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 18 CS (Off ) 5 pF typ CD (Off ) 5 pF typ CD, CS (On) 10 pF typ POWER REQUIREMENTS VDD = 13.2 V IDD 0.001 μA typ Digital inputs = 0 V or VDD 1.0 μA max IDD 220 μA typ Digital inputs = 5 V 380 μA max 1 Temperature range for Y Version is −40°C to +105°C. 2 Guaranteed by design, not subject to production test. Rev. A | Page 4 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
