Datasheet ADG726, ADG732 (Analog Devices)
Description | 16-/32-Channel, 4 Ω, +1.8 V to +5.5 V and ±2.5 V Analog Multiplexers |
Pages / Page | 21 / 1 — 16-/32-Channel, 4 Ω, +1.8 V to +5.5 V and. ±2.5 V Analog Multiplexers. … |
Revision | C |
File Format / Size | PDF / 350 Kb |
16-/32-Channel, 4 Ω, +1.8 V to +5.5 V and. ±2.5 V Analog Multiplexers. Data Sheet. ADG726. /ADG732. FEATURES
16-/32-Channel, 4 Ω, +1.8 V to +5.5 V and ±2.5 V Analog Multiplexers Data Sheet ADG726 /ADG732 FEATURES FUNCTIONAL BLOCK DIAGRAMS 1.8 V to 5.5 V single-supply operation ADG726 ±2.5 V dual-supply operation S1A On resistance: 4 Ω at 25°C (+5 V single supply/±2.5 V dual DA supply) S16A 0.5 Ω on-resistance flatness at 25°C (+5 V single supply/ ±2.5 V dual supply) S1B Rail-to-rail operation DB S16B Transition times: 23 ns typical at 25°C Single 32-to-1 channel multiplexer WR 1-OF-16 Dual/differential 16-to-1 channel multiplexer CSA DECODER TTL-/CMOS-compatible inputs CSB
1 00
48-lead TQFP or 48-lead, 7 mm × 7 mm LFCSP
5-
A0 A1 A2 A3 EN
0276
Figure 1.
Optical applications ADG732 Data acquisition systems S1 Communication systems Relay replacement D Audio and video switching Battery-powered systems Medical instrumentation S32 Automatic test equipment (ATE) WR 1-OF-32 DECODER CS
-002
A0 A1 A2 A3 A4 EN
2765 0 Figure 2.
GENERAL DESCRIPTION
closely matched between switches and very flat over the full signal The ADG726/ADG732 are monolithic, complementary metal range. These devices can operate equally well as either multiplexers oxide semiconductor (CMOS) 32-channel and dual 16-channel or demultiplexers and have an input signal range that extends analog multiplexers. The ADG732 switches one of 32 inputs (S1 to to the supplies. In the off condition, signal levels up to the S32) to a common output, D, as determined by the 5-bit binary supplies are blocked. All channels exhibit break-before-make address lines A0, A1, A2, A3, and A4. The ADG726 switches one switching action, preventing momentary shorting when switching of 16 inputs as determined by the 4-bit binary address lines A0, A1, channels. A2, and A3. The ADG726/ADG732 are available in a 48-lead LFCSP or a 48- On-chip latches facilitate microprocessor interfacing. The ADG726 lead TQFP. For functionally equivalent devices with serial interface, see the ADG725/ADG731. may also be configured for differential operation by tying CSA and CSB together. An EN input is used to enable or disable the
PRODUCT HIGHLIGHTS
devices. When disabled, all channels are switched off. 1. +1.8 V to +5.5 V single- or ±2.5 V dual-supply operation. These multiplexers are designed on an enhanced submicron These devices are specified and guaranteed with +5 V ± 10%, process that provides low power dissipation yet gives high +3 V ± 10% single-supply, and ±2.5 V ± 10% dual-supply switching speed, very low on resistance, and leakage currents. rails. They operate from a single supply of +1.8 V to +5.5 V and a 2. An on resistance of 4 Ω. ±2.5 V dual supply, making them ideally suited to a variety of 3. Guaranteed break-before-make switching action. applications. On resistance is in the region of a few ohms and is 4. 48-lead LFCSP package or 48-lead TQFP package.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. No license is granted by implication or otherwise under any patent or patent rights of Analog Tel: 781.329.4700 ©2002–2021 Analog Devices, Inc. All rights reserved. Devices. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS +5 V SINGLE SUPPLY +3 V SINGLE SUPPLY ±2.5 V DUAL SUPPLY TIMING CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTION 48-LEAD TQFP 48-LEAD LFCSP Truth Tables TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
