Datasheet ADG726, ADG732 (Analog Devices) - 9
Description16-/32-Channel, 4 Ω, +1.8 V to +5.5 V and ±2.5 V Analog Multiplexers
Pages / Page21 / 9 — Data Sheet. ADG726/ADG732. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameter …
RevisionC
File Format / SizePDF / 350 Kb
Data Sheet. ADG726/ADG732. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameter Rating. ESD CAUTION
Data Sheet ADG726/ADG732 ABSOLUTE MAXIMUM RATINGS Table 5 Parameter Rating ESD CAUTION
TA = 25°C, unless otherwise noted. Stresses at or above those listed under Absolute Maximum
Table 5.
Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these
Parameter Rating
or any other conditions above those indicated in the VDD to VSS 7 V operational section of this specification is not implied. VDD to GND −0.3 V to +7 V Operation beyond the maximum operating conditions for VSS to GND +0.3 V to −7 V extended periods may affect product reliability. Analog Inputs1 VSS − 0.3 V to VDD + 0.3 V or 30 mA, whichever occurs first
ESD CAUTION
Digital Inputs1 –0.3 V to VDD + 0.3 V or 30 mA, whichever occurs first Peak Current, S or D (Pulsed at 1 ms, 60 mA 10% Duty Cycle Maximum) Continuous Current, S or D 30 mA Operating Temperature Range ADG726 −40°C to +85°C ADG732 −40°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C Thermal Impedance θJA (4-Layer Board) 48-Lead LFCSP 25°C/W 48-Lead TQFP 54.6°C/W Reflow Soldering Peak Temperature, As per JEDEC J-STD-020 Pb Free 1 Overvoltages at A, EN, WR, CS, S, or D will be clamped by internal diodes. Current should be limited to the maximum ratings given. Rev. C | Page 9 of 21 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS +5 V SINGLE SUPPLY +3 V SINGLE SUPPLY ±2.5 V DUAL SUPPLY TIMING CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTION 48-LEAD TQFP 48-LEAD LFCSP Truth Tables TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
