Datasheet ADG613-EP (Analog Devices)
Description | 1 pC Charge Injection, 100 pA Leakage, CMOS, ±5 V/ +5 V/ +3 V, Quad SPST Switches |
Pages / Page | 12 / 1 — 1 pC Charge Injection, 100 pA Leakage,. CMOS, ±5 V/5 V/3 V, Quad SPST … |
Revision | A |
File Format / Size | PDF / 258 Kb |
1 pC Charge Injection, 100 pA Leakage,. CMOS, ±5 V/5 V/3 V, Quad SPST Switches. Enhanced Product. ADG613-EP. FEATURES
1 pC Charge Injection, 100 pA Leakage, CMOS, ±5 V/5 V/3 V, Quad SPST Switches Enhanced Product ADG613-EP FEATURES FUNCTIONAL BLOCK DIAGRAM 1 pC charge injection ADG613-EP ±0.1 nA maximum at 25°C leakage currents S1 85 Ω on resistance IN1 D1 Rail-to-rail switching operation S2 Fast switching times IN2 16-lead TSSOP D2 Typical power consumption: ≤11 nW S3 TTL-/CMOS-compatible inputs IN3 D3 VSS to VDD analog signal range S4 ±2.7 V to ±5.5 V dual supply operation IN4
001
2.7 V to 5.5 V single-supply operation D4 Fully specified at ±5 V, 3 V, and 5 V
14533- Figure 1.
ENHANCED PRODUCT FEATURES Supports defense and aerospace applications (AQEC standard) Military temperature range: −55°C to +125°C Controlled manufacturing baseline 1 assembly site 1 test site 1 fabrication site Enhanced product change notification Qualification data available on request APPLICATIONS Automatic test equipment Data acquisition systems Battery-powered systems Communications systems Sample-and-hold systems Audio signal routing Relay replacement Avionics GENERAL DESCRIPTION
The ADG613-EP is a monolithic CMOS device containing four ADG613-EP exhibits break-before-make switching action. independently selectable switches. This switch offers ultralow The ADG613-EP is available in a smal , 16-lead TSSOP package. charge injection of 1 pC over the ful input signal range and typical leakage currents of 0.01 nA at 25°C. The ADG613-EP is also a TTL-compatible device. The device is ful y specified for ±5 V, 5 V, and 3 V supplies. It Additional application and technical information can be found contains four independent single-pole, single-throw (SPST) in the ADG613 data sheet. switches. The ADG613-EP contains two switches with digital
PRODUCT HIGHLIGHTS
control logic that turns on with logic low and two switches in 1. Ultralow charge injection (1 pC typical y). which the logic is inverted. 2. Dual ±2.7 V to ±5.5 V or single 2.7 V to 5.5 V operation. Each switch conducts equal y wel in both directions when on 3. Temperature range: −55°C to +125°C. and has an input signal range that extends to the supplies. The 4. Small, 16-lead TSSOP.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2016 Analog Devices, Inc. Al rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technica l Support www.analog.com
Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DUAL-SUPPLY OPERATION SINGLE-SUPPLY OPERATION ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
