Datasheet ADG619, ADG620 (Analog Devices) - 6
DescriptionCMOS, ±5 V/+5 V, 4 Ω, Single SPDT Switches
Pages / Page16 / 6 — ADG619/ADG620. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter Rating. ESD …
RevisionC
File Format / SizePDF / 367 Kb
ADG619/ADG620. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter Rating. ESD CAUTION
ADG619/ADG620 ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating ESD CAUTION
link to page 6 link to page 6
TA = 25°C, unless otherwise noted.
Stresses above those listed under Absolute Maximum Ratings V may cause permanent damage to the device. This is a stress DD to VSS 13 V V rating only; functional operation of the device at these or any DD to GND −0.3 V to +6.5 V V other conditions above those indicated in the operational SS to GND +0.3 V to −6.5 V Analog Inputs1 V section of this specification is not implied. Exposure to absolute SS − 0.3 V to VDD + 0.3 V Digital Inputs1 −0.3 V to V maximum rating conditions for extended periods may affect DD + 0.3 V or 30 mA (whichever occurs first) device reliability. Peak Current, S or D 100 mA (pulsed at 1 ms, 10% duty cycle maximum) Only one absolute maximum rating may be applied at a time.
ESD CAUTION
Continuous Current, S or D 50 mA Operating Temperature Range Industrial (B Version) −40°C to +85°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C MSOP θJA Thermal Impedance 206°C/W θJC Thermal Impedance 44°C/W SOT-23 θJA Thermal Impedance 229.6°C/W θJC Thermal Impedance 91.99°C/W Lead Temperature, Soldering 300°C (10 sec) IR Reflow, Peak Temperature 220°C 1 Overvoltages at IN, S, or D are clamped by internal diodes. Current should be limited to the maximum ratings given. Rev. C | Page 6 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
