Datasheet ADG411, ADG412, ADG413 (Analog Devices)
DescriptionLC2MOS Precision Quad SPST Switches
Pages / Page16 / 1 — LC2MOS. Precision Quad SPST Switches. ADG411/ADG412/ADG413. FEATURES. 44 …
RevisionD
File Format / SizePDF / 222 Kb
LC2MOS. Precision Quad SPST Switches. ADG411/ADG412/ADG413. FEATURES. 44 V supply maximum ratings. ±15 V analog signal range
Datasheet ADG411, ADG412, ADG413 Analog Devices, Revision: D
LC2MOS Precision Quad SPST Switches ADG411/ADG412/ADG413 FEATURES
The ADG411, ADG412, and ADG413 contain four independent
SPST switches. The ADG411 and ADG412 differ only in that
the digital control logic is inverted. The ADG411 switches are
Low on resistance (< 35 Ω)
turned on with a logic low on the appropriate control input,
Ultralow power dissipation (35 μW)
while a logic high is required for the ADG412. The ADG413
Fast switching times
has two switches with digital control logic similar to that of the
t
ADG411 while the logic is inverted on the other two switches.
ON < 175 ns tOFF < 145 ns
Each switch conducts equally well in both directions when on,
TTL-/CMOS-compatible
and each has an input signal range that extends to the supplies.
Plug-in replacement for DG411/DG412/DG413
In the off condition, signal levels up to the supplies are blocked.
All switches exhibit break-before-make switching action for use in multiplexer applications. Inherent in the design is low charge
Audio and video switching
injection for minimum transients when switching the digital
Automatic test equipment
inputs.
Precision data acquisition PRODUCT HIGHLIGHTS Battery-powered systems Sample-and-hold systems
1. Extended signal range
Communication systems
The ADG411, ADG412, and ADG413 are fabricated on an enhanced LC2MOS, giving an increased signal range which
GENERAL DESCRIPTION
extends fully to the supply rails. The ADG411, ADG412, and ADG413 are monolithic CMOS 2. Ultralow power dissipation devices comprising four independently selectable switches. 3. Low R They are designed on an enhanced LC2MOS process which ON provides low power dissipation yet gives high switching speed 4. Break-before-make switching and low on resistance. This prevents channel shorting when the switches are configured as a multiplexer. The on resistance profile is very flat over the full analog input range ensuring excellent linearity and low distortion when 5. Single-supply operation switching audio signals. Fast switching speed coupled with high For applications where the analog signal is unipolar, the signal bandwidth also make the parts suitable for video signal ADG411, ADG412, and ADG413 can be operated from a switching. CMOS construction ensures ultralow power single-rail power supply. The parts are fully specified with a dissipation, making the parts ideally suited for portable and single 12 V power supply and remain functional with single battery-powered instruments. supplies as low as 5 V.
FUNCTIONAL BLOCK DIAGRAMS S1 S1 S1 IN1 IN1 IN1 D1 D1 D1 S2 S2 S2 IN2 IN2 IN2 D2 D2 D2 ADG411 ADG412 ADG413 S3 S3 S3 IN3 IN3 IN3 D3 D3 D3 S4 S4 S4 IN4 IN4 IN4 D4 D4 D4 SWITCHES SHOWN FOR A LOGIC 1 INPUT
00024-001
00024-002
00024-003 Figure 1. ADG411 Figure 2. ADG412 Figure 3. ADG413
Rev. D Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2010 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY APPLICATIONS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
