Datasheet ADG511, ADG512, ADG513 (Analog Devices)
DescriptionLC2MOS Precision 5 V/3 V Quad SPST Switches
Pages / Page12 / 1 — LC2MOS. Precision 5 V/3 V Quad SPST Switches. ADG511/ADG512/ADG513. …
RevisionC
File Format / SizePDF / 143 Kb
LC2MOS. Precision 5 V/3 V Quad SPST Switches. ADG511/ADG512/ADG513. FEATURES. FUNCTIONAL BLOCK DIAGRAMS. +3 V, +5 V or
Datasheet ADG511, ADG512, ADG513 Analog Devices, Revision: C
a
LC2MOS Precision 5 V/3 V Quad SPST Switches ADG511/ADG512/ADG513 FEATURES FUNCTIONAL BLOCK DIAGRAMS +3 V, +5 V or 5 V Power Supplies Ultralow Power Dissipation (<0.5 W) S1 S1 S1 Low Leakage (<100 pA) IN1 IN1 IN1 Low On Resistance (<50 D1 D1 ) D1 S2 S2 S2 Fast Switching Times IN2 IN2 IN2 Low Charge Injection D2 D2 D2 ADG511 ADG512 ADG513 TTL/CMOS Compatible S3 S3 S3 IN3 IN3 IN3 16-Lead DIP or SOIC Package D3 D3 D3 S4 S4 S4 APPLICATIONS IN4 IN4 IN4 Battery-Powered Instruments D4 D4 D4 Single Supply Systems SWITCHES SHOWN FOR A LOGIC "1" INPUT Remote Powered Equipment 5 V Supply Systems Computer Peripherals such as Disk Drives Precision Instrumentation
The ADG511, ADG512 and ADG513 contain four indepen-
Audio and Video Switching
dent SPST switches. The ADG511 and ADG512 differ only in
Automatic Test Equipment
that the digital control logic is inverted. The ADG511 switch is
Precision Data Acquisition
turned on with a logic low on the appropriate control input,
Sample Hold Systems
while a logic high is required for the ADG512. The ADG513
Communication Systems
contains two switches whose digital control logic is similar to
Compatible with 5 V Supply DACs and ADCs such as
that of the ADG511 while the logic is inverted in the remaining
AD7840/AD7848, AD7870/AD7871/AD7872/AD7874/
two switches.
AD7875/AD7876/AD7878 PRODUCT HIGHLIGHTS GENERAL DESCRIPTION
1. 5 Volt Single Supply Operation The ADG511, ADG512 and ADG513 are monolithic CMOS The ADG511/ADG512/ADG513 offers high performance, ICs containing four independently selectable analog switches. including low on resistance and wide signal range, fully These switches feature low, well-controlled on resistance and specified and guaranteed with +3 V, ± 5 V as well as +5 V wide analog signal range, making them ideal for precision supply rails. analog signal switching. 2. Ultralow Power Dissipation These switch arrays are fabricated using Analog Devices’ CMOS construction ensures ultralow power dissipation. advanced linear compatible CMOS (LC2MOS) process which 3. Low RON offers the additional benefits of low leakage currents, ultralow 4. Break-Before-Make Switching power dissipation and low capacitance for fast switching speeds Switches are guaranteed to have break-before-make opera- with minimum charge injection. These features make the tion. This allows multiple outputs to be tied together for ADG511, ADG512 and ADG513 the optimum choice for a multiplexer applications without the possibility of momentary wide variety of signal switching tasks in precision analog signal shorting between channels. processing and data acquisition systems. The ability to operate from single +3 V, +5 V or ± 5 V bipolar supplies make the ADG511, ADG512 and ADG513 perfect for use in battery-operated instruments, 4–20 mA loop systems and with the new generation of DACs and ADCs from Analog Devices. The use of 5 V supplies and reduced operating currents give much lower power dissipation than devices operating from ±15 V supplies. REV. C Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that
may result from its use. No license is granted by implication or otherwise
Tel: 781/329-4700 www.analog.com
under any patent or patent rights of Analog Devices.
Fax: 781/326-8703 © Analog Devices, Inc., 2001
