Datasheet ADG201A-EP (Analog Devices)
DescriptionLC2MOS Quad SPST Switches
Pages / Page8 / 1 — LC2MOS. Quad SPST Switches. ADG201A-EP. FEATURES. FUNCTIONAL BLOCK …
File Format / SizePDF / 178 Kb
LC2MOS. Quad SPST Switches. ADG201A-EP. FEATURES. FUNCTIONAL BLOCK DIAGRAM. 44 V supply maximum rating. ±15 V analog signal range
Datasheet ADG201A-EP Analog Devices
LC2MOS Quad SPST Switches ADG201A-EP FEATURES FUNCTIONAL BLOCK DIAGRAM 44 V supply maximum rating ADG201A-EP ±15 V analog signal range S1 Low R IN1 ON (60 Ω) D1 Low leakage (0.5 nA) S2 Break before make switching IN2 Low power dissipation D2 Available in a 16-lead SOIC package S3 Replaces DG201A, HI-201 IN3 D3 ENHANCED PRODUCT FEATURES S4 IN4 Supports defense and aerospace applications D4 (AQEC standard)
001
Military temperature range: −55°C to +125°C NOTES 1. SWITCHES SHOWN FOR A LOGIC1 INPUT.
09249-
Controlled manufacturing baseline
Figure 1.
One assembly and test site One fabrication site Enhanced product change notification Qualification data available on request GENERAL DESCRIPTION PRODUCT HIGHLIGHTS
The ADG201A-EP is a monolithic CMOS device comprising 1. Extended signal range of ±15 V. four independently selectable switches. They are designed on an 2. Operates with 15 V single supply voltages. enhanced LC2MOS process, which gives an increased signal 3. Low leakage: 500 pA. handling capability of ±15 V. These switches also feature high switching speeds and low RON.
Table 1. Truth Table
The ADG201A-EP exhibits break before make switching action.
INx Switch Condition
Inherent in the design is low charge injection for minimum 0 On transients when switching the digital inputs. 1 Off Full details about this enhanced product are available in the ADG201A data sheet, which should be consulted in conjunc- tion with this data sheet.
Rev. 0 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2011 Analog Devices, Inc. All rights reserved.
Document Outline Features Enhanced Product Features Functional Block Diagram General Description Product Highlights Revision History Specifications Dual Supply Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Test Circuits Outline Dimensions Ordering Guide
