Datasheet ADG888 (Analog Devices) - 7
Description0.4 Ω CMOS, Dual DPDT Switch in WLCSP/LFCSP/TSSOP
Pages / Page17 / 7 — Data Sheet. ADG888. BALL A1 INDICATOR. S4A. S1A. S4B. GND. S1B. S3B. IN2. …
RevisionD
File Format / SizePDF / 323 Kb
Data Sheet. ADG888. BALL A1 INDICATOR. S4A. S1A. S4B. GND. S1B. S3B. IN2. IN1. S2B. S3A. S2A. TOP VIEW. (BALL SIDE DOWN). Not to Scale
Data Sheet ADG888 BALL A1 INDICATOR S4A S1A S4B GND S1B S3B IN2 IN1 S2B S3A S2A TOP VIEW (BALL SIDE DOWN) Not to Scale
Data Sheet ADG888 BALL A1 INDICATOR 1 2 3 4 D4 S4A S1A D1 A S4B V GND DD S1B B S3B IN2 IN1 S2B C D3 S3A S2A D2 D ADG888 TOP VIEW (BALL SIDE DOWN)
002
Not to Scale (SOLDER BALLS ON OPPOSITE SIDE)
05432- Figure 4. 16-Ball WLCSP Pin Configuration
Table 5. WLCSP Pin Function Descriptions WLCSP Pin No. Mnemonic Description
1A D4 Drain Terminal 4. Can be an input or output. 2A S4A Source Terminal 4A. Can be an input or output. 3A S1A Source Terminal 1A. Can be an input or output. 4A D1 Drain Terminal 1. Can be an input or output. 1B S4B Source Terminal 4B. Can be an input or output. 2B GND Ground (0 V) Reference. 3B VDD Most Positive Power Supply Potential. 4B S1B Source Terminal 1B. Can be an input or output. 1C S3B Source Terminal 3B. Can be an input or output. 2C IN2 Logic Control Input. 3C IN1 Logic Control Input. 4C S2B Source Terminal 2B. Can be an input or output. 1D D3 Drain Terminal 3. Can be an input or output. 2D S3A Source Terminal 3A. Can be an input or output. 3D S2A Source Terminal 2A. Can be an input or output. 4D D2 Drain Terminal 2. Can be an input or output.
Table 6. Truth Table Logic (IN1/IN2) Switch S1A/S2A/S3A/S4A Switch S1B/S2B/S3B/S4B
0 Off On 1 On Off Rev. D | Page 7 of 17 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Outline Dimensions Ordering Guide
