Datasheet FLS122 (Flusso)
ManufacturerFlusso
DescriptionThe Smallest Air Velocity Sensor
Pages / Page2 / 1 — Sensing solutions. FLS122. Key benefits. Data centre. Gaming PCs. HVAC …
File Format / SizePDF / 324 Kb
Sensing solutions. FLS122. Key benefits. Data centre. Gaming PCs. HVAC filter. Consumer. thermal. monitoring. appliances. management
Datasheet FLS122 Flusso
Sensing solutions
Product information
FLS122
The smallest air velocity sensor FLS122 is designed for high-volume consumer goods applications requiring an air velocity
Key benefits
measurement. It will add value to your • Solid-state sensor product by providing an accurate air speed or • Ultra-low power air flow measurement with near-zero pressure • High precision drop. The FLS122 often requires no flow • Near-zero pressure drop fixture and integrates easily into an existing • Ultra-small footprint duct. It measures air velocity directly using a • Mass airflow calculation thermal sensing method and can be calibrated • Easy mechanical integration to report air velocity or air flow rate. It is • Mass production uniquely suited to applications with large flow rates but small pressure drops. Applications Applica
Data centre Gaming PCs HVAC filter Consumer thermal thermal monitoring appliances management management
FL-001908-SM, 2022-04-27
