Databrief TDA7901 (STMicroelectronics)
DescriptionHigh efficiency digital input automotive quad power amplifier with built-in diagnostics features, Class-G integrated, "start stop" compatible
Pages / Page13 / 1 — TDA7901. Features. Product status link. Product summary. Order code. …
File Format / SizePDF / 217 Kb
TDA7901. Features. Product status link. Product summary. Order code. Package. Packing. Description. DB4653. Rev 1. January 2022
Databrief TDA7901 STMicroelectronics
TDA7901
Data brief High efficiency digital input automotive quad power amplifier with built-in diagnostics features, Class-G integrated, ’start stop’ compatible
Features
• AEC-Q100 qualification ongoing GAPGPS00071 • 24-bit resolution PowerSO36 (Slug-up) • High Resolution Bandwidth support: – Up to 40 kHz (I2S 96 kHz) with attenuation [0 dB, -2 dB] – Up to 80 kHz (I2S 192 kHz) with attenuation [0 dB, -2 dB] • 117 dB dynamic range (A-weighted) • Real-time load current monitoring • Voltage monitoring feature on I2C • High Efficiency SB-I (SB-Improved) and Class-G operation • 1 Ω driving capability • High output power capability: – 4 x 27 W 4Ω@ 14.4 V, 1 kHz, THD = 10 % – 4 x 47 W 2Ω@ 14.4 V, 1 kHz, THD = 10 % • Flexible mode control: – Full I2C bus driving (1.8 V/3.3 V) with eight addresses selectable – Independent front/rear play/mute – Selectable digital gains – Very low noise – Digital diagnostic with DC and AC load Detections
Product status link
– Digital diagnostic with OL and OD in play TDA7901 – Current Offset Detection
Product summary
• EMI compliance evaluated following normative CISPR25 • Start-stop compatibility (operation down to 4.5 V)
Order code Package Packing
• Sample rates: 44.1 kHz, 48 kHz, 96 kHz, 192 kHz Tape and TDA7901-ZST PowerSO36 • Flexible serial data port (1.8 V/3.3 V): reel (Slug-up) – I2S standard, TDM 4Ch, TDM 8Ch, TDM 16Ch TDA7901-ZSX Tube • Output Voltage Offset Detector • Independent front/rear clipping detector • Programmable diagnostic pin • CMOS compatible enable pin • Thermal protection • Pop free in mute to play transitions and vice versa
The TDA7901 is a single-chip quad-bridge amplifier in advanced BCD technology integrating: a full D/A converter, digital input for direct connection to I2S (or TDM) and powerful MOSFET output stages.
DB4653
Rev 1
January 2022
www.st.com For further information contact your local STMicroelectronics sales office. Document Outline 1 Block diagram and pins description 1.1 Block diagram 1.2 Pin description 2 Electrical specifications 2.1 Thermal data 3 General description 4 Package information 4.1 PowerSO-36 (slug up) package information Revision history
