Datasheet EL8202, EL8203, EL8403 (Renesas)
ManufacturerRenesas
Description500MHz Rail-to-Rail Amplifiers
Pages / Page16 / 1 — NOT RECOMMENDED FOR NEW DESIGNS. NO RECOMMENDED REPLACEMENT. contact our …
NOT RECOMMENDED FOR NEW DESIGNS. NO RECOMMENDED REPLACEMENT. contact our Technical Support Center at
Datasheet EL8202, EL8203, EL8403 Renesas
DATASHEET EL8202, EL8203, EL8403
FN7106 500MHz Rail-to-Rail Amplifiers
Rev 2.00
April 26, 2006
1-888-INTERSIL or www.intersil.com/tsc
The EL8202, EL8203, and EL8403 represent rail-to-rail
Features
amplifiers with a -3dB bandwidth of 500MHz and slew rate of 600V/µs. Running off a very low supply current of 5.6mA per • 500MHz -3dB bandwidth channel, the EL8202, EL8203, and EL8403 also feature • 600V/µs slew rate inputs that go to 0.15V below the VS- rail. The EL8202 and • Low supply current = 5.6mA per channel EL8203 are dual channel amplifiers. The EL8403 is a quad channel amplifier. • Supplies from 3V to 5.5V The EL8202 includes a fast-acting disable/power-down • Rail-to-rail output circuit. With a 25ns disable and a 200ns enable, the EL8202 • Input to 0.15V below VS- is ideal for multiplexing applications. • Fast 25ns disable (EL8202 only) The EL8202, EL8203, and EL8403 are designed for a • Low cost number of general purpose video, communication, instrumentation, and industrial applications. The EL8202 is • Pb-free plus anneal available (RoHS compliant) available in a 10 Ld MSOP package, the EL8203 in 8 Ld SO and 8 Ld MSOP packages, and the EL8403 in 14 Ld SO and
Applications
16 Ld QSOP packages. All are specified for operation over • Video amplifiers the -40°C to +85°C temperature range. • Portable/hand-held products • Communications devices
Ordering Information Ordering Information (Continued) PART PART TAPE & PKG. PART PART TAPE & PKG. NUMBER MARKING REEL PACKAGE DWG. # NUMBER MARKING REEL PACKAGE DWG. #
EL8202IY m - 10 Ld MSOP MDP0043 EL8403IS 8403IS - 14 Ld SO MDP0027 EL8202IY-T7 m 7” 10 Ld MSOP MDP0043 EL8403IS-T7 8403IS 7” 14 Ld SO MDP0027 EL8202IY-T13 m 13” 10 Ld MSOP MDP0043 EL8403IS-T13 8403IS 13” 14 Ld SO MDP0027 EL8202IYZ BAPAA - 10 Ld MSOP MDP0043 EL8403ISZ 8403ISZ - 14 Ld SO MDP0027 (See Note) (Pb-free) (See Note) (Pb-free) EL8202IYZ-T7 BAPAA 7” 10 Ld MSOP MDP0043 EL8403ISZ-T7 8403ISZ 7” 14 Ld SO MDP0027 (See Note) (Pb-free) (See Note) (Pb-free) EL8202IYZ-T13 BAPAA 13” 10 Ld MSOP MDP0043 EL8403ISZ-T13 8403ISZ 13” 14 Ld SO MDP0027 (See Note) (Pb-free) (See Note) (Pb-free) EL8203IS 8203IS - 8 Ld SO MDP0027 EL8403IU 8403IU - 16 Ld QSOP MDP0040 EL8203IS-T7 8203IS 7” 8 Ld SO MDP0027 EL8403IU-T7 8403IU 7” 16 Ld QSOP MDP0040 EL8203IS-T13 8203IS 13” 8 Ld SO MDP0027 EL8403IU-T13 8403IU 13” 16 Ld QSOP MDP0040 EL8203ISZ 8203ISZ - 8 Ld SO MDP0027 EL8403IUZ 8403IUZ - 16 Ld QSOP MDP0040 (See Note) (Pb-free) (See Note) (Pb-free) EL8203ISZ-T7 8203ISZ 7” 8 Ld SO MDP0027 EL8403IUZ-T7 8403IUZ 7” 16 Ld QSOP MDP0040 (See Note) (Pb-free) (See Note) (Pb-free) EL8203ISZ-T13 8203ISZ 13” 8 Ld SO MDP0027 EL8403IUZ-T13 8403IUZ 13” 16 Ld QSOP MDP0040 (See Note) (Pb-free) (See Note) (Pb-free) EL8203IY BJAAA - 8 Ld MSOP MDP0043 NOTE: Intersil Pb-free plus anneal products employ special Pb-free material sets; molding compounds/die attach materials and 100% matte EL8203IY-T7 BJAAA 7” 8 Ld MSOP MDP0043 tin plate termination finish, which are RoHS compliant and compatible EL8203IY-T13 BJAAA 13” 8 Ld MSOP MDP0043 with both SnPb and Pb-free soldering operations. Intersil Pb-free products are MSL classified at Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J STD-020. FN7106 Rev 2.00 Page 1 of 16 April 26, 2006
