Datasheet CA3080, CA3080A (Intersil)
ManufacturerIntersil
Description2MHz, Operational Transconductance Amplifier (OTA)
Pages / Page11 / 1 — Features. Applications. Pinouts. CA3080. (PDIP, SOIC). Part Number …
Features. Applications. Pinouts. CA3080. (PDIP, SOIC). Part Number Information. 8 NC. PART NUMBER. TEMP. PKG. (BRAND). RANGE (oC). PACKAGE. NO. INV
Datasheet CA3080, CA3080A Intersil
DATASHEET CA3080, CA3080A FN475 2MHz, Operational Transconductance Amplifier (OTA) Rev.6.00 Jan 13, 2017 The CA3080 and CA3080A types are Gatable-Gain Blocks
Features
which utilize the unique operational-transconductance- amplifier (OTA) concept described in Application Note • Slew Rate (Unity Gain, Compensated) . 50V/s AN6668, “Applications of the CA3080 and CA3080A High- • Adjustable Power Consumption . .10W to 30W Performance Operational Transconductance Amplifiers”. • Flexible Supply Voltage Range . 2V to 15V The CA3080 and CA3080A types have differential input and a • Fully Adjustable Gain . .0 to g single-ended, push-pull, class A output. In addition, these types MRL Limit have an amplifier bias input which may be used either for gating • Tight gM Spread: or for linear gain control. These types also have a high output - CA3080. 2:1 impedance and their transconductance (gM) is directly - CA3080A . 1.6:1 proportional to the amplifier bias current (IABC). • Extended gM Linearity . 3 Decades The CA3080 and CA3080A types are notable for their excellent slew rate (50V/s), which makes them especially useful for
Applications
multiplexer and fast unity-gain voltage followers. These types • Sample and Hold • Multiplier are especially applicable for multiplexer applications because power is consumed only when the devices are in the “ON” • Multiplexer • Comparator channel state. • Voltage Follower The CA3080A’s characteristics are specifically controlled for
Pinouts
applications such as sample-hold, gain-control, multiplexing,
CA3080
etc.
(PDIP, SOIC)
TOP VIEW
Part Number Information 1 8 NC PART NUMBER TEMP. PKG. NC (BRAND) RANGE (oC) PACKAGE NO. INV. 2 7 INPUT V+ -
CA3080AE -55 to 125 8 Ld PDIP E8.3
NON-INV. + 3 6 OUTPUT INPUT
CA3080AM -55 to 125 8 Ld SOIC M8.15
AMPLIFIER
(3080A)
4 5 V- BIAS INPUT
CA3080AM96 -55 to 125 8 Ld SOIC Tape M8.15 (3080A) and Reel CA3080E 0 to 70 8 Ld PDIP E8.3 CA3080M 0 to 70 8 Ld SOIC M8.15 (3080) CA3080M96 0 to 70 8 Ld SOIC Tape M8.15 (3080) and Reel FN475 Rev.6.00 Page 1 of 11 Jan 13, 2017
