Datasheet CA3080, CA3080A (Intersil) - 3
ManufacturerIntersil
Description2MHz, Operational Transconductance Amplifier (OTA)
Pages / Page11 / 3 — Electrical Specifications. (Continued). CA3080. CA3080A. PARAMETER. TEST …
Electrical Specifications. (Continued). CA3080. CA3080A. PARAMETER. TEST CONDITIONS. TEMP. MIN. TYP. MAX. UNITS. Schematic Diagram. Q6 Q7
Electrical Specifications (Continued) CA3080 CA3080A PARAMETER TEST CONDITIONS TEMP MIN TYP MAX UNITS Schematic Diagram Q6 Q7
CA3080, CA3080A
For Equipment Design, VSUPPLY = 15V, Unless Otherwise Specified
(Continued) CA3080 CA3080A PARAMETER TEST CONDITIONS TEMP MIN TYP MAX MIN TYP MAX UNITS
Peak Output Positive IABC = 5A, RL =  25 - 13.8 - 12 13.8 - V Voltage Negative 25 - -14.5 - -12 -14.5 - V Positive IABC = 500A, RL =  25 12 13.5 - 12 13.5 - V Negative 25 -12 -14.4 - -12 -14.4 - V Amplifier Supply Current IABC = 500A 25 0.8 1 1.2 0.8 1 1.2 mA Device Dissipation IABC = 500A 25 24 30 36 24 30 36 mW IABC = 0, VTP = 0 25 - 0.08 - - 0.08 5 nA Magnitude of Leakage Current IABC = 0, VTP = 36V 25 - 0.3 - - 0.3 5 nA Propagation Delay IABC = 500A 25 - 45 - - 45 - ns Common-Mode Rejection Ratio IABC = 500A 25 80 110 - 80 110 - dB Open-Loop Bandwidth IABC = 500A 25 - 2 - - 2 - MHz Slew Rate Uncompensated 25 - 75 - - 75 - V/s Compensated 25 - 50 - - 50 - V/s
Schematic Diagram 7 V+ D3 Q D 4 3 D2 Q6 Q7 Q5 D4 Q9 Q8 INVERTING OUTPUT INPUT 2 Q1 Q2 NON- 6 INVERTING 3 INPUT Q10 AMPLIFIER 5 Q3 Q11 BIAS INPUT V- D1 D6 4 Typical Applications V+ = 15V VS =
15V 0.01
F 62k 7 10k 5 LOAD 3 + (SCOPE PROBE) 390pF 51 CA3080, A 6 OUTPUT 300 1V/DIV. 5pF 2 - 1M 4 0.01
F 10k V- = -15V INPUT 5V/DIV. 0.001
F TIME (0.1
s/DIV.) FIGURE 1. SCHEMATIC DIAGRAM OF THE CA3080 AND CA3080A IN A UNITY-GAIN VOLTAGE FOLLOWER CONFIGURATION AND ASSOCIATED WAVEFORM
FN475 Rev.6.00 Page 3 of 11 Jan 13, 2017
