Datasheet CA3280, CA3280A (Intersil) - 3
ManufacturerIntersil
DescriptionDual, 9MHz, Operational Transconductance Amplifier (OTA)
Pages / Page10 / 3 — Electrical Specifications. (Continued) (Continued). CA3280. CA3280A. …
File Format / SizePDF / 664 Kb
Electrical Specifications. (Continued) (Continued). CA3280. CA3280A. PARAMETER. SYMBOL. TEST CONDITIONS. MIN. TYP. MAX. UNITS
Electrical Specifications (Continued) (Continued) CA3280 CA3280A PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNITS
CA3280, CA3280A
For Equipment Design, at TA = 25oC, VSUPPLY= 15V, Unless Otherwise Specified
(Continued) (Continued) CA3280 CA3280A PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
Peak Output Current IOM+ IABC = 500A Source 350 410 650 350 410 650 A IOM- Sink -350 -410 -650 -350 -410 -650 A IOM+ IABC = 5A Source 3 4.1 7 3 4.1 7 A IOM- Sink -3 -4.1 -7 -3 -4.1 -7 A Peak Output Current Sink and IOM-, IABC = 500A, TA = Full 350 450 550 350 450 550 A Source IOM+ Temperature Range Linearization Diodes ID = 100A - 10 - - 10 - A Offset Current ID = 10A - 0.5 1 - 0.5 1 A Dynamic Impedance ID = 100A - 700 - - 700 - Diode Network Supply Current IABC = 100A 250 400 800 250 400 800 A Amplifier Supply Current I+ IABC = 500A - 2 2.4 - 2 2.4 mA (Per Amplifier) Amplifier Output Leakage Current IOL IABC = 0, VO = 0V - 0.015 0.1 - 0.015 0.1 nA IABC = 0, VO = 30V - 0.15 1 - 0.15 1 nA Common Mode Rejection Ratio CMRR IABC = 100A 80 100 - 94 100 - dB Power Supply Rejection Ratio PSRR IABC = 100A 86 105 - 94 105 - dB Open Loop Voltage Gain AOL IABC = 100A, 94 100 - 94 100 - dB RL = VO = 20VP-P 50 100 - 50 100 - kV/V Forward Transconductance GM IABC = 50A, Large Signal - 0.8 1.2 - 0.8 1.2 mS gM IABC = 1mA, Small Signal - 16 22 - 16 22 mS Input Resistance RI IABC = 10A 0.5 - - 0.5 - - M Channel Separation f = 1kHz - 94 - - 94 - dB Open Loop Total THD f = 1kHz, IABC = 1.5mA, - 0.4 - - 0.4 - % Harmonic Distortion RL = 15k, VO = 20VP-P Bandwidth fT IABC = 1mA, RL = 100 - 9 - - 9 - MHz Slew Rate, Open Loop SR IABC = 1mA - 125 - - 125 - V/s Capacitance CI IABC = 100A Input - 4.5 - - 4.5 - pF CO Output - 7.5 - - 7.5 - pF Output Resistance RO IABC = 100A - 63 - - 63 - M FN1174 Rev 6.00 Page 3 of 10 May 2002
