Datasheet BlueNRG-LPS (STMicroelectronics) - 9
DescriptionProgrammable Bluetooth Low Energy Wireless SoC
Pages / Page63 / 9 — BlueNRG-LPS. Power supply management. Figure 4. Power supply …
File Format / SizePDF / 8.2 Mb
BlueNRG-LPS. Power supply management. Figure 4. Power supply configuration. 1.6.2. Power supply schemes
BlueNRG-LPS Power supply management Figure 4 Power supply configuration 1.6.2 Power supply schemes
BlueNRG-LPS Power supply management Figure 4. Power supply configuration 1.6.2 Power supply schemes
The BlueNRG-LPS embeds three power domains: • VDD33 (VDDIO or VDD): – the voltage range is between 1.7 V and 3.6 V – it supplies a part of the I/O ring, the embedded regulators and the system analog IPs as power management block and embedded oscillators • VDD12o: – always-on digital power domain – this domain is generally supplied at 1.2 V during active phase of the device – this domain is supplied at 1.0 V during low power mode (DEEPSTOP) • VDD12i: – interruptible digital power domain – this domain is generally supplied at 1.2 V during active phase of the device – this domain is shut down during low power mode (DEEPSTOP)
Figure 5. Power supply domain overview 1.6.3 Linear voltage regulators
The digital power supplies are provided by different regulators:
DS13819
Rev 2 page 9/63
Document Outline Features Applications Description 1 Functional overview 1.1 System architecture 1.2 Arm® Cortex®-M0+ core with MPU 1.3 Memories 1.3.1 Embedded Flash memory 1.3.2 Embedded SRAM 1.3.3 Embedded ROM 1.3.4 Embedded OTP 1.3.5 Memory protection unit (MPU) 1.4 Security and safety 1.5 RF subsystem 1.5.1 RF front-end block diagram 1.6 Power supply management 1.6.1 SMPS step-down regulator 1.6.2 Power supply schemes 1.6.3 Linear voltage regulators 1.6.4 Power supply supervisor 1.7 Operating modes 1.7.1 RUN mode 1.7.2 DEEPSTOP mode 1.7.3 SHUTDOWN mode 1.8 Reset management 1.9 Clock management 1.10 Boot mode 1.11 Embedded UART bootloader 1.12 General purpose inputs/outputs (GPIO) 1.13 Direct memory access (DMA) 1.14 Nested vectored interrupt controller (NVIC) 1.15 Analog digital converter (ADC) 1.15.1 Temperature sensor 1.16 True random number generator (RNG) 1.17 Timers and watchdog 1.17.1 General-purpose timers (TIM2, TIM16, TIM17) 1.17.2 Independent watchdog (IWDG) 1.17.3 SysTick timer 1.18 Real-time clock (RTC) 1.19 Inter-integrated circuit interface (I2C) 1.20 Universal synchronous/asynchronous receiver transmitter (USART) 1.21 LPUART 1.22 Serial peripheral interface (SPI) 1.23 Inter-IC sound (I2S) 1.24 Serial wire debug port 1.25 TX and RX event alert 1.26 Direction finding 2 Pinouts and pin description 3 Memory mapping 4 Application circuits 5 Electrical characteristics 5.1 Parameter conditions 5.1.1 Minimum and maximum values 5.1.2 Typical values 5.1.3 Typical curves 5.1.4 Loading capacitor 5.1.5 Pin input voltage 5.2 Absolute maximum ratings 5.3 Operating conditions 5.3.1 Summary of main performance 5.3.2 General operating conditions 5.3.3 RF general characteristics 5.3.4 RF transmitter characteristics 5.3.5 RF receiver characteristics 5.3.6 Embedded reset and power control block characteristics 5.3.7 Supply current characteristics 5.3.8 Wake-up time from low power modes 5.3.9 High speed crystal requirements 5.3.10 Low speed crystal requirements 5.3.11 High speed ring oscillator characteristics 5.3.12 Low speed ring oscillator characteristics 5.3.13 PLL characteristics 5.3.14 Flash memory characteristics 5.3.15 Electrostatic discharge (ESD) 5.3.16 I/O port characteristics 5.3.17 RSTN pin characteristics 5.3.18 ADC characteristics 5.3.19 Temperature sensor characteristics 5.3.20 Timer characteristics 5.3.21 I2C interface characteristics 5.3.22 SPI characteristics 6 Package information 6.1 QFN32 (5x5x0.9, pitch 0.5 mm) package information 6.2 WLCSP36 package information 6.3 Thermal characteristics 7 Ordering information Revision history
