Datasheet NCV5230 (ON Semiconductor) - 4
ManufacturerON Semiconductor
DescriptionOperational Amplifier, Low Voltage
Pages / Page19 / 4 — NCV5230. DC AND AC ELECTRICAL CHARACTERISTIC. Characteristic. Symbol. …
Revision6
File Format / SizePDF / 349 Kb
NCV5230. DC AND AC ELECTRICAL CHARACTERISTIC. Characteristic. Symbol. Test Conditions. Bias. Min. Typ. Max. Unit. www.onsemi.com
NCV5230 DC AND AC ELECTRICAL CHARACTERISTIC Characteristic Symbol Test Conditions Bias Min Typ Max Unit www.onsemi.com
Unless otherwise specified, ±0.9V ≤ Vs ≤ ±7.5 V or equivalent single supply, RL = 10 kW, full input common−mode range, over full operating temperature range.
Characteristic Symbol Test Conditions Bias Min Typ Max Unit NCV5230
Large−Signal Open−Loop Gain AVOL VS = ±7.5 V High 120 2000 V/mV RL = 10 kW; TA = 25°C Low 60 750 High 100 TA = Tlow to Thigh Low 50 Output Voltage Swing VOUT TA = 25°C +SW Any 750 800 mV TA = 25°C −SW Any 750 800 VS = ±0.9 V TA = Tlow to Thigh; +SW Any 700 TA = Tlow to Thigh; −SW Any 700 TA = 25°C +SW Any 7.30 7.35 V TA = 25°C −SW Any −7.32 −7.35 VS = ±7.5 V TA = Tlow to Thigh; +SW Any 7.25 7.30 TA = Tlow to Thigh; −SW Any −7.30 −7.35 Slew Rate SR High 0.25 V/ms TA = 25°C Low 0.09 V/ms Inverting Unity Gain Bandwidth BW High 0.6 MHz CL = 100 pF; TA = 25°C Low 0.25 MHz Phase Margin qM CL = 100 pF; TA = 25°C Any 70 ° Settling Time tS High 2.0 ms CL = 100 pF, 0.1% Low 5.0 ms Input Noise VINN High 30 nV/√Hz RS = 0 W; f = 1.0 kHz Low 60 nV/√Hz Total Harmonic Distortion THD VS = ±7.5 V % AV = 1; VIN = 500 mV; f = 1.0 kHz High 0.003 VS = ±0.9 V % AV = 1, VIN = 500 mV; f = 1.0 kHz High 0.002 For NCV5230 devices, Tlow = −40°C and Thigh = +125°C.
www.onsemi.com 4
