Datasheet ADR390, ADR391, ADR392, ADR395 (Analog Devices)
Description | Micropower, Low Noise Precision Voltage References with Shutdown |
Pages / Page | 20 / 1 — Micropower, Low Noise Precision Voltage. References with Shutdown. … |
File Format / Size | PDF / 490 Kb |
Micropower, Low Noise Precision Voltage. References with Shutdown. ADR390/ADR391/ADR392/ADR395. FEATURES. PIN CONFIGURATION
Micropower, Low Noise Precision Voltage References with Shutdown ADR390/ADR391/ADR392/ADR395 FEATURES PIN CONFIGURATION Compact 5-lead TSOT packages SHDN 1 ADR390/ 5 GND Low temperature coefficient ADR391/ VIN 2 ADR392/ B grade: 9 ppm/°C ADR395
01
A grade: 25 ppm/°C VOUT (SENSE) 3 4 V
0
(Not to Scale) OUT (FORCE)
9- 41
Initial accuracy
00 Figure 1. 5-Lead TSOT (UJ Suffix)
B grade: ±4 mV maximum (ADR390) A grade: ±6 mV maximum Table 1. Ultralow output noise: 5 μV p-p (0.1 Hz to 10 Hz) Temperature Low dropout: 300 mV Output Coefficient Accuracy Low supply current Model Voltage (VO) (ppm/°C) (mV) 3 μA maximum in shutdown
ADR390B 2.048 9 ±4
120 μA maximum in operation
ADR390A 2.048 25 ±6
No external capacitor required
ADR391B 2.5 9 ±4
Output current: 5 mA
ADR391A 2.5 25 ±6
Wide temperature range: −40°C to +125°C
ADR392B 4.096 9 ±5
ADR392A 4.096 25 ±6 ADR395B 5.0 9 ±5
Battery-powered instrumentation
ADR395A 5.0 25 ±6
Portable medical instrumentation Data acquisition systems Industrial process controls Automotive GENERAL DESCRIPTION
The ADR390/ADR391/ADR392/ADR395 are precision 2.048 V, The ADR39x family of micropower, low dropout voltage 2.5 V, 4.096 V, and 5 V band gap voltage references, respectively, references provides a stable output voltage from a minimum featuring low power and high precision in a tiny footprint. Using supply of 300 mV above the output. Their advanced design patented temperature drift curvature correction techniques eliminates the need for external capacitors, which further from Analog Devices, Inc., the ADR39x references achieve a reduces board space and system cost. The combination of low 9 ppm/°C of temperature drift in the TSOT package. low power operation, small size, and ease of use makes the ADR39x precision voltage references ideally suited for battery- operated applications.
Rev. G Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2002–2008 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ADR390 ELECTRICAL CHARACTERISTICS ADR391 ELECTRICAL CHARACTERISTICS ADR392 ELECTRICAL CHARACTERISTICS ADR395 ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION DEVICE POWER DISSIPATION CONSIDERATIONS SHUTDOWN MODE OPERATION APPLICATIONS INFORMATION BASIC VOLTAGE REFERENCE CONNECTION Stacking Reference ICs for Arbitrary Outputs A Negative Precision Reference without Precision Resistors General-Purpose Current Source High Power Performance with Current Limit CAPACITORS Input Capacitor Output Capacitor OUTLINE DIMENSIONS ORDERING GUIDE
