Datasheet 1N4099 (MCC) - 4
ManufacturerMCC
Description500mW Silicon Zener Diodes
Pages / Page5 / 4 — Micro Commercial Components. Figure 4. Maximum Surge Power 1.8-91 Volts. …
File Format / SizePDF / 200 Kb
Micro Commercial Components. Figure 4. Maximum Surge Power 1.8-91 Volts. Figure 5. Effect of Zener Current on
Micro Commercial Components Figure 4 Maximum Surge Power 1.8-91 Volts Figure 5 Effect of Zener Current on
1N4614 thru 1N4125 M C C TM
100 70 RECT ANGULAR 50 11V-91V NONREPETITIVE WAVEFORM TTS) TJ = 25°C PRIOR TO A 30 5% DUTY CYCLE 1.8V-10V NONREPETITIVE INITIAL PULSE 20 10 10% DUTY CYCLE 7 5 20% DUTY CYCLE 3 , PEAK SURGE POWER (W 2 pkP 1 0.01 0.02 0.05 0.1 0.2 0.5 1 2 5 10 20 50 100 200 500 1000 PW, PULSE WIDTH (ms)
1000 500 TJ = 25°C VZ = 2.7V iZ(rms) = 0.1 Iz(dc) f = 60 Hz 200 47V 100 27V 50 20 10 6.2V 5 , DYNAMIC IMPEDANCE (OHMS) ZZ 2 1 0.1 0.2 0.5 1 2 5 10 20 50 100 IZ , ZENER CURRENT (mA)
Figure 5. Effect of Zener Current on Zener Impedance
1000 1000 700 TJ = 25°C MAXIMUM 500 iZ (rms) = 0.1 IZ (dc) 500 MINIMUM f = 60Hz IZ = 1mA 200 200 (mA) 100 100 70 5mA 50 50 20mA 20 20 75 °C ARD CURRENT W 10 10 7 25 °C , DYNAMIC IMPEDANCE (OHMS) 5 , FOR 5 Z F 150 °C Z I 0°C 2 2 1 1 1 2 3 5 7 10 20 30 50 70 100 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 VZ , ZENER VOLTAGE (VOLTS) VF , FOR WARD VOLTAGE (VOLTS)
Figure 6. Effect of Zener Voltage on Zener Impedance Figure 7. Typical Forward Characteristics
www.mccsemi.com Revision: B 2012/01/01
4 of 5
