Datasheet KBU4A, KBU4B, KBU4D, KBU4G, KBU4J, KBU4K, KBU4M (Vishay) - 2
ManufacturerVishay
DescriptionSingle-Phase Bridge Rectifier
Pages / Page4 / 2 — KBU4A, KBU4B, KBU4D, KBU4G, KBU4J, KBU4K, KBU4M. THERMAL CHARACTERISTICS. …
File Format / SizePDF / 85 Kb
KBU4A, KBU4B, KBU4D, KBU4G, KBU4J, KBU4K, KBU4M. THERMAL CHARACTERISTICS. PARAMETER. SYMBOL KBU4A. KBU4B. KBU4D. KBU4G. KBU4J. KBU4K
KBU4A, KBU4B, KBU4D, KBU4G, KBU4J, KBU4K, KBU4M THERMAL CHARACTERISTICS PARAMETER SYMBOL KBU4A KBU4B KBU4D KBU4G KBU4J KBU4K
www.vishay.com Vishay General Semiconductor
(TA = 25 °C unless otherwise noted)
PARAMETER SYMBOL KBU4A KBU4B KBU4D KBU4G KBU4J KBU4K KBU4M UNIT
RθJA 19 (2) Typical thermal resistance °C/W RθJL 4.0 (1)
Notes
(1) Units mounted on a 2.0" x 1.6" x 0.3" thick (5 cm x 4 cm x 0.8 cm) aluminum plate (2) Units mounted on PCB with 0.5" x 0.5" (12 mm x 12 mm) copper pads and 0.375" (9.5 mm) lead length
ORDERING INFORMATION
(Example)
PREFERRED P/N UNIT WEIGHT (g) PREFERRED PACKAGE CODE BASE QUANTITY DELIVERY MODE
KBU4J-E4/51 8.0 51 250 Anti-static PVC tray
RATINGS AND CHARACTERISTICS CURVES
(TA = 25 °C unless otherwise noted) 4 100 60 Hz Resistive or Inductive Load 3 rrent (A) u rrent (A) 10 u Heatsink Mounting, ard C ard C 2 T , 2.0 x 1.6 x 3.0" C rw w (5.0 x 4.0 x 0.8 cm) o T = 25 °C r J o Al. Plate Pulse Width = 300 µs s F u 1 % Duty Cycle 1 age F 1 er v T , A PCB Mounting A 0.47" x 0.47" (12 x 12 mm) Copper Pads Instantaneo 0 0.1 0 50 100 150 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 Temperature (°C) Instantaneous Forward Voltage (V) Fig. 1 - Derating Curve Output Rectified Current Fig. 3 - Typical Forward Characteristics Per Diode 200 50 T = 150 °C J 175 Single Sine-Wave 10 rrent (A) 150 rrent (µA) u u T = 100 °C J 125 rge C u erse C v 1 100 ard S s Re u rw o 75 0.1 eak F T = 25 °C 50 J P Instantaneo 25 0.01 1 10 100 0 20 40 60 80 100 Number of Cycles at 60 Hz Percent of Rated Peak Reverse Voltage (%) Fig. 2 - Maximum Non-Repetitive Peak Forward Surge Fig. 4 - Typical Reverse Leakage Characteristics Per Diode Current Per Diode Revision: 14-Apr-2020
2
Document Number: 88656 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
