Datasheet SFH610A, SFH6106 (Vishay) - 3
Manufacturer | Vishay |
Description | Optocoupler, Phototransistor Output, High Reliability, 5300 VRMS |
Pages / Page | 9 / 3 — SFH610A, SFH6106. CURRENT TRANSFER RATIO PARAMETER. TEST CONDITION. PART. … |
File Format / Size | PDF / 178 Kb |
SFH610A, SFH6106. CURRENT TRANSFER RATIO PARAMETER. TEST CONDITION. PART. SYMBOL. MIN. TYP. MAX. UNIT
SFH610A, SFH6106
CURRENT TRANSFER RATIO PARAMETER TEST CONDITION PART SYMBOL MIN. TYP. MAX. UNIT
SFH610A-1 CTR 40 - 80 % SFH6106-1 CTR 40 - 80 % SFH610A-2 CTR 63 - 125 % SFH6106-2 CTR 63 - 125 % SFH610A-3 CTR 100 - 200 % IF = 10 mA, VCE = 5.0 V SFH6106-3 CTR 100 - 200 % SFH610A-4 CTR 160 - 320 % SFH6106-4 CTR 160 - 320 % SFH610A-5 CTR 250 - 500 % IC/IF SFH6106-5 CTR 250 - 500 % SFH610A-1 CTR 13 30 - % SFH6106-1 CTR 13 30 - % SFH610A-2 CTR 22 45 - % SFH6106-2 CTR 22 45 - % IF = 1 mA, VCE = 5 V SFH610A-3 CTR 34 70 - % SFH6106-3 CTR 34 70 - % SFH610A-4 CTR 56 90 - % SFH6106-4 CTR 56 90 - %
SWITCHING CHARACTERISTICS PARAMETER TEST CONDITION PART SYMBOL MIN. TYP. MAX. UNIT NON-SATURATED
Current VCC = 5 V, RL = 75 Ω IF - 10 - mA Rise time VCC = 5 V, RL = 75 Ω tr - 2 - μs Fall time VCC = 5 V, RL = 75 Ω tf - 2 - μs Turn-on time VCC = 5 V, RL = 75 Ω ton - 3 - μs Turn-off time VCC = 5 V, RL = 75 Ω toff - 2.3 - μs Cut-off frequency VCC = 5 V FCO - 250 - kHz
SATURATED
SFH610A-1 IF - 20 - mA SFH6106-1 SFH610A-2 IF - 10 - mA SFH6106-2 Current SFH610A-3 IF - 10 - mA SFH6106-3 SFH610A-4 IF - 5 - mA SFH6106-4
SATURATED
SFH610A-1 tr - 2 - μs SFH6106-1 SFH610A-2 tr - 3 - μs SFH6106-2 Rise time SFH610A-3 tr - 3 - μs SFH6106-3 SFH610A-4 tr - 4 - μs SFH6106-4 Rev. 2.5, 28-Mar-18
3
Document Number: 83666 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
