MAX965–MAX970 Single/Dual/Quad, Micropower, Ultra-Low-Voltage, Rail-to-Rail I/O Comparators Pin Descriptions (continued)MAX969/MAX970PINMAX970NAMEFUNCTIONMAX969SOQSOP 1 1 1 OUTB Comparator B Open-Drain Output 2 2 2 OUTA Comparator A Open-Drain Output 3 3 3 VCC Positive Supply Voltage, +1.6V to +5.5V 4 4 4 INA- Comparator A Inverting Input 5 5 5 INA+ Comparator A Noninverting Input 6 6 6 INB- Comparator B Inverting Input 7 7 7 INB+ Comparator B Noninverting Input — — 8, 9 N.C. No Connection. Not internally connected. 8 — — REF Internal Reference Output. Typically 1.235V with respect to GND. 9 — — HYST Hysteresis Input. Connect to REF if not used. Input voltage range is from (VREF - 50mV) to VREF. 10 8 10 INC- Comparator C Inverting Input 11 9 11 INC+ Comparator C Noninverting Input 12 10 12 IND- Comparator D Inverting Input 13 11 13 IND+ Comparator D Noninverting Input 14 12 14 GND Ground 15 13 15 OUTD Comparator D Open-Drain Output 16 14 16 OUTC Comparator C Open-Drain Output Detailed Description tor configured as a dual voltage monitor with common The MAX965–MAX970 single/dual/quad, micropower, hysteresis adjustment and a reference output. The dual ultra-low-voltage comparators feature rail-to-rail inputs MAX968 is similar to the MAX967, but is configured and outputs and an internal 1.235V ±1.5% bandgap as a window comparator. The MAX969 is a quad com- reference. These devices operate from a single +1.6V parator with a common hysteresis adjustment and a to +5.5V supply voltage range, and consume less than reference output pin. The MAX970 is a quad comparator 5µA supply current per comparator over the extended without a reference and without hysteresis adjustment. temperature range. Internal hysteresis is programmable (See Functional Diagrams and Selector Guide.) up to ±50mV using two external resistors and the device’s Comparator Input internal reference. The rail-to-rail input common-mode The MAX965–MAX970 have a -0.25V to V voltage range and the open-drain outputs allow easy CC input common-mode range. Both comparator inputs may oper- voltage-level conversion for multivoltage systems. All ate at any differential voltage within the common-mode inputs and outputs can tolerate a continuous short-circuit voltage range, and the comparator displays the correct fault condition to either rail. output logic state. The MAX965 is a single comparator with adjustable hysteresis and a reference output pin. The MAX966 is Low-Voltage Operation: VCC Down to 1V a dual comparator without the reference and without The minimum operating voltage is 1.6V. As the sup- adjustable hysteresis. The MAX967 is a dual compara- ply voltage falls below 1.6V, performance degrades and supply current falls. The reference does not www.maximintegrated.com Maxim Integrated │ 7
