Datasheet ADA4097-1, ADA4097-2 (Analog Devices) - 7
Description50 V, 130 kHz, 32.5 µA per Channel, Robust, Over-The-Top, Precision Op Amps
Pages / Page31 / 7 — ADA4097-1/ADA4097-2. SPECIFICATIONS. Table 2. B Grade. H Grade. …
ADA4097-1/ADA4097-2. SPECIFICATIONS. Table 2. B Grade. H Grade. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit. analog.com
ADA4097-1/ADA4097-2 SPECIFICATIONS Table 2 B Grade H Grade Parameter Test Conditions/Comments Min Typ Max Unit analog.com
link to page 7 link to page 7 link to page 5 Data Sheet
ADA4097-1/ADA4097-2 SPECIFICATIONS Table 2. B Grade H Grade Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
Short-Circuit Current ISOURCE 20 30 20 30 mA TMIN < TA < TMAX 10 6 mA ISINK 35 45 35 45 mA TMIN < TA < TMAX 10 6 mA POWER SUPPLY Maximum Operating Voltage4 50 50 V VSY Range Guaranteed by PSRR 3 50 3 50 V Supply Current per Channel Amplifier active 40 44 40 44 µA TMIN < TA < TMAX 65 70 µA VSY = ±25 V 42 48 42 48 µA TMIN < TA < TMAX 70 75 µA Amplifier shutdown, VSHDN = −VS + 15 22.5 15 22.5 µA 1.5 V TMIN < TA < TMAX 25 25 µA PSRR VSY = 3 V to 50 V 123 145 123 145 dB TMIN < TA < TMAX 120 120 dB THERMAL SHUTDOWN5 Temperature TJ 175 175 °C Hysteresis 20 20 °C Operating Temperature TA −40 +125 −55 +150 °C 1 Thermoelectric voltages present in the high speed production test limit the measurement accuracy of this parameter. The limits shown in Table 2 are determined by test capability and are not necessarily indicative of actual device performance. 2 Offset voltage drift is guaranteed through lab characterization and is not production tested. 3 VOD is +30 mV for VOUT high and −30 mV for VOUT low. 4 Maximum operating voltage is limited by the TDDB of the on-chip capacitor oxides. The amplifier tolerates temporary transient overshoot up to the specified absolute maximum rating and the dc supply voltage must be limited to the maximum operating voltage. 5 Thermal shutdown is lab characterized only and is not tested in production.
analog.com Rev. A | 7 of 31
Document Outline Features Applications General Description Typical Application Circuit Specifications 5 V Supply ±15 V Supply Absolute Maximum Ratings Maximum Power Dissipation Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for ADA4097-1/ADA4097-2 ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation Input Protection Over-The-Top Operation Considerations Output Shutdown Pins (SHDN and SHDNx) Applications Information Large Resistor Gain Operation Recommended Values for Various Gains Noise Distortion Power Dissipation and Thermal Shutdown Circuit Layout Considerations Power Supply Bypassing Grounding ESD Protection when Powered Related Products Typical Applications Outline Dimensions Ordering Guide Evaluation Boards
