PRELIMINARY SiT1881 Automotive Ultra-Low Power, Low Jitter 32.768 kHz Oscillator Table 2. Absolute Maximum Ratings Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. ParametersTest ConditionsValueUnitContinuous Power Supply Voltage Range (VDD) -0.5 to 3.63 V Continuous Maximum Operating Temperature Range 125 °C Short Duration Maximum Operating Temperature Range ≤ 30 minutes 130 °C Human Body Model (HBM) ESD Protection JESD22-A114 2000 V Charge-Device Model (CDM) ESD Protection JESD22-C101 500 V Machine Model (MM) ESD Protection JESD22-A115 200 V Latch-up Tolerance JESD78 Compliant Mechanical Shock Resistance Mil 883, Method 2002 30,000 g Mechanical Vibration Resistance Mil 883, Method 2007 100 g Max Junction Temperature 130 °C Storage Temperature -65 to 150 °C Table 3. Pin ConfigurationPinSymbolI/OFunctionality 1 CLK-0 Out Oscillator Clock Output 2 GND Power Supply Ground Connect to Ground 3 NC NC No Connect 4 NC NC No Connect 5 VDD Power Supply Device supply voltage. Under normal operating conditions, VDD does not require external bypass/decoupling capacitor(s). SiT1881 includes on-chip VDD filtering. 6 NC NC No Connect Table 4. Environmental ComplianceParameterCondition/Test methodAEC-Q100Grade 2 Rev 0.8 Page 5 of 8 Proprietary & Confidential of SiTime
