Datasheet 2381 691 90001/HUMIDITY-SENS-E (Vishay)
ManufacturerVishay
DescriptionHumidity Sensor
Pages / Page2 / 1 — 2381 691 90001/HUMIDITY-SENS-E. Humidity Sensor. APPLICATIONS. …
File Format / SizePDF / 121 Kb
2381 691 90001/HUMIDITY-SENS-E. Humidity Sensor. APPLICATIONS. DESCRIPTION. QUICK REFERENCE DATA. PARAMETER. VALUE. UNIT. MOUNTING
Datasheet 2381 691 90001/HUMIDITY-SENS-E Vishay
Vishay BCcomponents
Humidity Sensor APPLICATIONS
• Humidity measurements in electronic hygrometers for domestic use • Self-regulating air humidifiers, etc.
DESCRIPTION
This capacitive atmospheric humidity sensor consists of a
non-conductive foil, which is covered on both sides with a
PARAMETER VALUE UNIT
layer of gold. The dielectric constant of the foil changes as a Humidity range (RH) 10 to 90 % function of the relative humidity of the ambient atmosphere Capacitance at + 25 °C; 43 % RH; and, accordingly, the capacitance value of the sensor is a 122 ± 15 % pF 100 kHz measure for relative humidity. The foil is clamped between Tan δ at + 25 °C; 100 kHz; 43 % RH ≤ 0.035 contact springs and assembled in a plastic housing. It is Sensitivity between 12 % provided with two connecting pins which fit printed-circuit 0.4 ± 0.05 pF/%RH and 75 % RH boards with a grid pitch of 2.54 mm, provision is also made Frequency 1 to 1000 kHz for fastening with 3 mm bolts. The characteristics are not Temperature dependence + 0.1 %RH/K affected by incidental water condensation on the sensor foil. Response time in minutes It should not be exposed to either acetone or chlorine (to 90 % of indicated RH change at vapours. + 25 °C, in circulating air): Between 10 % and 43 % RH < 3
MOUNTING
Between 43 % and 90 % RH < 5 The device can be soldered directly on to a printed-circuit Hysteresis (for RH excursion ≈ 3 % board or fastened with 3 mm bolts. of 10 % to 90 % to 10 %) Maximum AC or DC voltage 15 V
SOLDERING
Storage humidity range (RH) 0 to 100 % Solderability: ≤ 240 °C; ≤ 4 s Ambient temperature range: Operating 0 to + 85 °C Resistance to heat: ≤ 240 °C; ≤ 4 s Storage - 25 to + 85 °C Weight ≈ 1.3 g
ROBUSTNESS OF TERMINATIONS Note
Tensile strength: 10 N Unless otherwise stated, measurements are in accordance with “IEC publication 60539”
ELECTRICAL CHARACTERISTICS
Component is 100 % lead (Pb)-free Component in accordance to RoHS 2002/95/EC and WEEE 2002/96/EC Stability is in accordance with “CECC 43000” and “IEC 60068-2” MEA832 150
DIMENSIONS
in millimeters C (pF) 15.5 ± 0.5 140 130 23.0 ± 0.5 3° 2.9 ± 0.2 3 120 1.15 max 5.08 110 3.1 ± 0.1 0 50 100 RH (%) 17.0 11.5 Typical capacitance as a function of relative humidity 5.0 ± 0.5 ± 0.5 ± 0.5 Component outline www.vishay.com For technical questions, contact: nlr@vishay.com Document Number: 29001 62 Revision: 24-Jun-09
