Datasheet BM1Z102FJ, BM1Z103FJ (Rohm)
ManufacturerRohm
DescriptionAC Voltage Zero Cross Detection IC
Pages / Page23 / 1 — C Voltage Zero Cross Detection IC. BM1Z102FJ BM1Z103FJ. General …
C Voltage Zero Cross Detection IC. BM1Z102FJ BM1Z103FJ. General Description. Key Specifications
Datasheet BM1Z102FJ, BM1Z103FJ Rohm
Datasheet
A C Voltage Zero Cross Detection IC BM1Z102FJ BM1Z103FJ General Description Key Specifications
This IC outputs the AC voltage zero cross timing VCC Input Power Supply Voltage Range: detection and the DC voltage after diode rectification with -0.3 V to +29.0 V high accuracy. VH_AC1 and VH_AC2 Pins Operation Voltage: By eliminating the need for photocoupler and external 600 V (Max) components required in conventional applications, it is VH_DC Pin Operation Voltage: 600 V (Max) possible to reduce the number of parts drastically and Circuit Current at Standby: 50 µA (Typ) realize compact and highly reliable power supply Circuit Current at Operation: 160 µA (Typ) applications. In addition, this IC can reduce standby Operating Temperature Range: -40 °C to +105 °C power largely in comparison with an existing photocoupler control.
Package W (Typ) x D (Typ) x H (Max) Features
SOP-J11 8.65 mm x 6.0 mm x 1.65 mm AC Zero Cross Detection Function Pitch (Typ): 1.27 mm Eliminates Photocoupler 600 V High Voltage Monitor Modifiable Zero Cross Delay Time n Channel Open Drain Output DC Voltage Monitor Function 600 V High Voltage Monitor VCC Under Voltage Locked Out (VCC UVLO)
Applications
Household Appliances such as Rice Cooker and Dryer, etc.
Lineup
Product Name ACOUT Pin Output Waveform BM1Z102FJ Pulse BM1Z103FJ Edge
Typical Application Circuit Motor AC/DC Filter
BM2P Series
DC/DC Motor
BM1Z10xFJ
Others
BD9E Series
Driver
C VC SET D D DC _ N G VH T 2 DC OU AC T
μ-Com
_ AC U O VH 1 AC _ VH 〇Product structure : Silicon integrated circuit 〇This product has no designed protection against radioactive rays . www.rohm.com
TSZ02201-0F1F0A200610-1-2
© 2019 ROHM Co., Ltd. All rights reserved. 1/20 TSZ22111 • 14 • 001
12.Mar.2020 Rev.001
Document Outline General Description Features Applications Key Specifications Package Lineup Typical Application Circuit Pin Configuration Pin Descriptions Block Diagram Description of Blocks 1. AC Voltage Zero Cross Detection 1.1 Startup Sequence 1.2 VH_AC1 Pin UVLO 1.3 VH_AC1 and VH_AC2 Pins Noise Filter 1.4 DSET Pin Setting 2. DC Voltage Monitor Circuit Absolute Maximum Ratings Thermal Loss Recommended Operating Conditions Electrical Characteristics Typical Performance Curves I/O Equivalence Circuit Operational Notes 1. Reverse Connection of Power Supply 2. Power Supply Lines 3. Ground Voltage 4. Ground Wiring Pattern 5. Recommended Operating Conditions 6. Inrush Current 7. Testing on Application Boards 8. Inter-pin Short and Mounting Errors 9. Unused Input Pins 10. Regarding the Input Pin of the IC 11. Ceramic Capacitor 12. Thermal Shutdown Circuit (TSD) 13. Over Current Protection Circuit (OCP) Ordering Information Marking Diagram Physical Dimension and Packing Information Revision History
