Datasheet BM1Z102FJ, BM1Z103FJ (Rohm) - 2
Manufacturer | Rohm |
Description | AC Voltage Zero Cross Detection IC |
Pages / Page | 23 / 2 — BM1Z102FJ BM1Z103FJ. Pin Configuration. Pin Descriptions. … |
File Format / Size | PDF / 1.3 Mb |
BM1Z102FJ BM1Z103FJ. Pin Configuration. Pin Descriptions. TSZ02201-0F1F0A200610-1-2. 12.Mar.2020 Rev.00
BM1Z102FJ BM1Z103FJ Pin Configuration
(TOP VIEW) N. C. 1 11 VH_AC1 N. C. 2 3 10 ACOUT VH_AC2 DCOUT 4 GND 5 9 VH_DC DSET 6 VCC 7 8 N. C.
Pin Descriptions
Pin No. Pin Name Function 1 N.C. Non connection 2 N.C. Non connection 3 ACOUT AC voltage zero cross timing output pin 4 DCOUT DC voltage output pin 5 GND Ground pin 6 DSET AC voltage zero cross delay time setting pin 7 VCC Power supply pin 8 N.C. Non connection (Do not connect to any pins.) 9 VH_DC DC voltage input pin 10 VH_AC2 AC voltage input 2 pin 11 VH_AC1 AC voltage input 1 pin www.rohm.com
© 2019 ROHM Co., Ltd. All rights reserved. 2/20 TSZ22111 • 15 • 001
12.Mar.2020 Rev.00 1
Document Outline General Description Features Applications Key Specifications Package Lineup Typical Application Circuit Pin Configuration Pin Descriptions Block Diagram Description of Blocks 1. AC Voltage Zero Cross Detection 1.1 Startup Sequence 1.2 VH_AC1 Pin UVLO 1.3 VH_AC1 and VH_AC2 Pins Noise Filter 1.4 DSET Pin Setting 2. DC Voltage Monitor Circuit Absolute Maximum Ratings Thermal Loss Recommended Operating Conditions Electrical Characteristics Typical Performance Curves I/O Equivalence Circuit Operational Notes 1. Reverse Connection of Power Supply 2. Power Supply Lines 3. Ground Voltage 4. Ground Wiring Pattern 5. Recommended Operating Conditions 6. Inrush Current 7. Testing on Application Boards 8. Inter-pin Short and Mounting Errors 9. Unused Input Pins 10. Regarding the Input Pin of the IC 11. Ceramic Capacitor 12. Thermal Shutdown Circuit (TSD) 13. Over Current Protection Circuit (OCP) Ordering Information Marking Diagram Physical Dimension and Packing Information Revision History
