Datasheet ADuM3165, ADuM3166 (Analog Devices)
Description3.75 kV RMS Digital Isolators for Isolated USB 2.0 High, Full, and Low Speed
Pages / Page26 / 1 — ADuM3165. /ADuM3166. FEATURES. FUNCTIONAL BLOCK DIAGRAMS. Figure 1. …
ADuM3165. /ADuM3166. FEATURES. FUNCTIONAL BLOCK DIAGRAMS. Figure 1. ADuM3165 (Clock Input from Host Side)
Datasheet ADuM3165, ADuM3166 Analog Devices
link to page 26 link to page 1 link to page 26 link to page 26 link to page 26 Data Sheet
ADuM3165 /ADuM3166
FEATURES FUNCTIONAL BLOCK DIAGRAMS
► USB 2.0 signaling with automatic detection of low, full, and high speed connections ► 1.5 Mbps, 12 Mbps, and 480 Mbps data rates ► Bidirectional USB isolator for upstream and downstream ports ► Redriving and high speed data retiming for input jitter removal and an open eye ► Flexible clock input options ► 4.5 V to 5.5 V VBUSx or 3 V to 3.6V operation on each side ► 21 mA typical idle, low or full speed mode supply current ► 48 mA typical idle, high speed mode supply current ► Ultra low power standby in USB 2.0 suspend (L2) or disconnect
► 1.7 mA typical low power standby, upstream supply current ► 20 μA typical low power standby, downstream supply current ► ±6000 V IEC 61000-4-2 ESD protection across the isolation barrier ► Passed CISPR32/EN55032 Class B emissions ► High common-mode transient immunity: 50 kV/μs typical ► Safety and regulatory approvals (pending) ► UL (pending): 3750 V rms for 1 minute per UL 1577 ► CSA Component Acceptance Notice 5A (pending) ► IEC 62368-1, IEC 61010-1, and IEC60601-1 ► VDE certificate of conformity (pending) ► DIN V VDE V 0884-11 (VDE V 0884-11):2017-01
Figure 2. ADuM3166 (Clock Input from Peripheral Side)
► VIORM = 849 VPEAK (working voltage)
GENERAL DESCRIPTION
► Operating temperature range: −55°C to +125°C ► Compact 20-lead SSOP with 5.3 mm creepage and clearance The ADuM3165/ADuM31661 are USB 2.0 port isolators, utilizing Analog Devices, Inc., iCoupler® technology to dynamically support
all USB 2.0 data rates: low (1.5 Mbps), full (12 Mbps), or high (480 Mbps), as required. The devices support host isolation with ► USB peripheral, USB host, and USB hub isolation automatic speed negotiation as well as peripheral isolation. ► Electronic test and measurement equipment High speed data is retimed for jitter reduction, requiring an external ► Medical devices and integrated PCs clock signal or crystal input. The ADuM3165 supports the clock or ► Industrial PCs and isolated USB ports for debug or upgrade crystal input on the upstream side, and the ADuM3166 supports the ► USB isolator modules and USB cable isolators clock or crystal input on the downstream side, offering two options to best suit the system design. The low power standby mode for downstream (Side 2) supports applications with limited available power, such as battery-operated peripherals. The upstream (Side 1) standby current meets USB 2.0 requirements for suspended operation. The isolators are specified over an extended industrial temperature range of −55°C to +125°C and are available in a compact 20-lead shrink small outline package (SSOP) with 5.3 mm creepage and clearance. 1 Protected by U.S. Patents 5,952,849; 6,873,065; 6,903,578; and 7,075,329. Other patents are pending.
Rev. 0 DOCUMENT FEEDBACK
Information furnished by Analog Devices is believed to be accurate and reliable "as is". However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and
TECHNICAL SUPPORT
registered trademarks are the property of their respective owners. Document Outline Features Applications Functional Block Diagrams General Description Specifications Timing Specifications Insulation and Safety Related Specifications Package Characteristics Regulatory Information DIN V VDE V 0884-11 (VDE V 0884-11) Insulation Characteristics (Pending) Recommended Operating Conditions Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for ADuM3165/ADuM3166 ESD Caution Pin Configurations and Function Descriptions Truth Tables Typical Performance Characteristics Terminology Bus Upstream and Downstream Hub Host Peripheral Enumeration Low Speed Full Speed High Speed End of Packet (EOP) J State K State SE0 State SE1 State Idle L1 Suspend L2 Suspend Theory of Operation Automatic Data Transfer and Modes Retimer and Other Features Isolator Characteristics and Low Power Modes Applications Information Power Supply Options Clock Options PGOOD, Clock, and Power Sequencing Isolated USB Implementations Peripheral Applications Host Applications Interface Applications PCB Layout and Electromagnetic Interference (EMI) Insulation Lifetime Surface Tracking Insulation Wear Out Calculation and Use of Parameters Example Outline Dimensions Ordering Guide Evaluation Boards
