Datasheet ADuM3165, ADuM3166 (Analog Devices) - 10
Description3.75 kV RMS Digital Isolators for Isolated USB 2.0 High, Full, and Low Speed
Pages / Page26 / 10 — ADuM3165/ADuM3166. ABSOLUTE MAXIMUM RATINGS. ELECTROSTATIC DISCHARGE …
ADuM3165/ADuM3166. ABSOLUTE MAXIMUM RATINGS. ELECTROSTATIC DISCHARGE (ESD) RATINGS
ADuM3165/ADuM3166 ABSOLUTE MAXIMUM RATINGS ELECTROSTATIC DISCHARGE (ESD) RATINGS
link to page 10 link to page 10 Data Sheet
The following ESD information is provided for handling of ESD-sen- sitive devices in an ESD protected area only. Human body model (HBM) per ANSI/ESDA/JEDEC JS-001. International electrotechnical commission (IEC) electromagnetic compatibility: Part 4-2 (IEC) per IEC 61000-4-2.
ESD Ratings for ADuM3165/ADuM3166 Table 11. ADuM3165/ADuM3166, 20-Lead SSOP ESD Model Withstand Threshold (V) Class
HBM1 ±4000 3A IEC2 ±6000 (contact discharge) Level 3 1 All pins to respective GNDx, 1.5 kΩ, 100 pF. 2 GND1 to GND2 or GND2 to GND1 across isolation barrier.
ESD CAUTION ESD (electrostatic discharge) sensitive device
. Charged devi- ces and circuit boards can discharge without detection. Although this product features patented or proprietary protection circuitry, damage may occur on devices subjected to high energy ESD. Therefore, proper ESD precautions should be taken to avoid performance degradation or loss of functionality.
analog.com Rev. 0 | 10 of 26
Document Outline Features Applications Functional Block Diagrams General Description Specifications Timing Specifications Insulation and Safety Related Specifications Package Characteristics Regulatory Information DIN V VDE V 0884-11 (VDE V 0884-11) Insulation Characteristics (Pending) Recommended Operating Conditions Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for ADuM3165/ADuM3166 ESD Caution Pin Configurations and Function Descriptions Truth Tables Typical Performance Characteristics Terminology Bus Upstream and Downstream Hub Host Peripheral Enumeration Low Speed Full Speed High Speed End of Packet (EOP) J State K State SE0 State SE1 State Idle L1 Suspend L2 Suspend Theory of Operation Automatic Data Transfer and Modes Retimer and Other Features Isolator Characteristics and Low Power Modes Applications Information Power Supply Options Clock Options PGOOD, Clock, and Power Sequencing Isolated USB Implementations Peripheral Applications Host Applications Interface Applications PCB Layout and Electromagnetic Interference (EMI) Insulation Lifetime Surface Tracking Insulation Wear Out Calculation and Use of Parameters Example Outline Dimensions Ordering Guide Evaluation Boards
