Datasheet AP43776Q (Diodes)
Manufacturer | Diodes |
Description | Automotive-Grade Dual-Channel USB Type-C Protocol Decoder |
Pages / Page | 13 / 1 — AP43776Q. AUTOMOTIVE-GRADE DUAL-CHANNEL USB TYPE-C PROTOCOL DECODER. … |
File Format / Size | PDF / 973 Kb |
AP43776Q. AUTOMOTIVE-GRADE DUAL-CHANNEL USB TYPE-C PROTOCOL DECODER. Description. Pin Assignments. (Top View). W-QFN4040-20
AP43776Q AUTOMOTIVE-GRADE DUAL-CHANNEL USB TYPE-C PROTOCOL DECODER Description Pin Assignments
The DIODES™ AP43776Q is a highly integrated, dual-channel, USB Type-C®, PD3.1 / PPS, BC 1.2 and QC protocol decoder. It passes
(Top View)
certification of USB Type-C power delivery specification Rev 3.1 with PPS and Quick ChargeTM QC5 protocol. The device can support the full range of PPS APDO (augmented power data object) from 3.3V to 21V with 20mV/step voltage resolution and up to 6A current with 50mA/step resolution for power management. To enable output current beyond 3A, the AP43776Q supports e-Marker cable detection with built-in VCONN switch with 30mA driving capability and over-current protection (OCP). Cable- loss compensations are also embedded. During the power charging, AP43776Q can support Display Port Alternate Mode by decoding out the CC signal and deliver the routing signal to the mux switch through I2C interface, Meanwhile, the AP43776Q also supports BC1.2 CDP handshaking. The AP43776Q provides an embedded MCU and built-in ADC converters for voltage and temperature measurement, where over- temperature protection (OTP) and other specific functions can be implemented through I2C pins and rich GPIO pins. Working in conjunction with two I2C-equipped Buck-Boost controllers or converters which have PD3.1 PPS output circuitry, the AP43776Q serves as the I2C master and supports two independent PD3.1 PPS
W-QFN4040-20
charging applications without using additional output enable MOS chips for each PD3.1 output port. With built-in firmware, the AP43776Q can support various smart power-management functions such as power-sharing scheme between two attached USB Type-C PD devices, low-battery power de-rating, thermal power de-rating, LED light indication, etc. Two AP43776Q devices can also be interconnected through a UART (GPIO) pin to implement smart power-sharing scheme for all four connected USB Type-C ports attached to a fixed power source.
Features Features
(continued) AEC-Q100 Qualified with the Following Results:
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)
Device Temperature Grade 1: -40°C to +125°C TA Range
Halogen and Antimony Free. “Green” Device (Note 3)
Device HBM ESD Classification Level H3A
The AP43776Q is suitable for automotive applications
Device CDM ESD Classification Level C5
requiring specific change control; this part is AEC-Q100
Dual-channel independent USB Type-C PD3.1/PPS decoder
qualified, PPAP capable, and manufactured in IATF 16949
USB-IF PD3.1/PPS certificated TID: 6206
certified facilities.
Quick Charge™ QC5 certificated No.: QC20211008263
https://www.diodes.com/quality/product-definitions/
PD3.1/ full range of PPS VOUT (3.3V to 21V) Compliant with BC1.2 DCP mode for QC2.0/3.0/4/4+/5
Applications
Type-C PD Display Port Alternative mode BC 1.2 CDP (Charging Downstream Port) mode for Charging In-vehicle multi-port USB PD3.1 charging systems Downstream device and allow data transfer Built-in ADC and multi-channel multiplexer for voltage and temperature measurement e-Marker detection and VCONN 30mA capability Cable-loss compensations I2C Interface and Interrupt Multi-purpose I/Os to support different applications CC1/CC2 to VBUS short protection up to 24V Moisture detection between DP and DN Thermal protection through external NTC Output power de-rating for low battery Built-in MCU with 12KB OTP ROM for main application program with multi-time-programmable ROM (MTP ROM) blocks for customization W-QFN4040-20(SWP) (4x4, 0.5mm pitch) package Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. AP43776Q 1 of 13 November 2022 Document number: DS43207 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated
