Datasheet ADuM4165, ADuM4166 (Analog Devices)
Description5.7 kV RMS Digital Isolators for Isolated USB 2.0 High, Full, and Low Speed
Pages / Page26 / 1 — ADuM4165. /ADuM4166. FEATURES. FUNCTIONAL BLOCK DIAGRAMS. Figure 1. …
ADuM4165. /ADuM4166. FEATURES. FUNCTIONAL BLOCK DIAGRAMS. Figure 1. ADuM4165 Clock Input from Host Side
Datasheet ADuM4165, ADuM4166 Analog Devices
link to page 26 link to page 26 link to page 1 Data Sheet
ADuM4165 /ADuM4166
FEATURES FUNCTIONAL BLOCK DIAGRAMS
► USB 2.0 signaling with automatic detection of low, full, and high speed connections ► 1.5 Mbps, 12 Mbps, and 480 Mbps data rates ► Bidirectional USB isolator for upstream or downstream ports ► Redriving and high speed data retiming for input jitter removal and an open eye ► Flexible clock input options ► 4.5 V to 5.5 V VBUSx or 3 V to 3.6 V operation on each side ► 21 mA typical idle, low or full speed mode supply current ► 48 mA typical idle, high speed mode supply current ► Ultra low power standby in USB 2.0 suspend (L2) or disconnect
► 1.7 mA typical low power standby, upstream supply current ► 20 μA typical low power standby, downstream supply current ► ±8000 V IEC 61000-4-2 ESD protection across the isolation barrier ► Passed CISPR32/EN55032 Class B emissions ► High common-mode transient immunity: 50 kV/μs typical ► Safety and regulatory approvals (pending) ► UL (pending): 5700 V rms for 1 minute per UL 1577 ► CSA Component Acceptance Notice 5A (pending) ► IEC 62368-1, IEC 61010-1 and IEC60601-1 ► VDE certificate of conformity (pending) ► DIN V VDE V 0884-11 (VDE V 0884-11):2017-01
Figure 2. ADuM4166 Clock Input from Peripheral Side
► VIORM = 849 VPEAK
GENERAL DESCRIPTION
► Operating temperature range: −55°C to +125°C ► 20-lead, wide-body, increased creepage SOIC_IC package with The ADuM4165/ADuM41661 are USB 2.0 port isolators, utilizing 8.3 mm creepage and clearance Analog Devices, Inc., iCoupler® technology to dynamically support all USB 2.0 data rates; low (1.5 Mbps), full (12 Mbps), or high
(480 Mbps), as required. The devices support host isolation with automatic speed negotiation as well as peripheral isolation. ► USB peripheral, USB host, and USB hub isolation ► Electronic test and measurement equipment High speed data is retimed for jitter reduction, requiring an external clock signal or crystal input. The ADuM4165 supports the clock or ► Medical devices and integrated PCs crystal input on the upstream side, and the ADuM4166 supports the ► Industrial PCs and isolated USB ports for debug or upgrade clock or crystal input on the downstream side, offering two options ► USB isolator modules and USB cable isolators to best suit the system design. The low power standby mode for downstream (Side 2) supports applications with limited available power, such as battery-operated peripherals. The upstream (Side 1) standby current meets USB 2.0 requirements for suspended operation. The isolators are specified over an extended industrial temperature range of −55°C to +125°C and are available in a 20-lead, wide- body, increased creepage SOIC_IC with 8.3 mm creepage and clearance. 1 Protected by U.S. Patents 7,075,329; 8,432,182; 8,525,547; and 8,564,327. Other patents are pending.
Rev. 0 DOCUMENT FEEDBACK
Information furnished by Analog Devices is believed to be accurate and reliable "as is". However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and
TECHNICAL SUPPORT
registered trademarks are the property of their respective owners. Document Outline Features Applications Functional Block Diagrams General Description Specifications Timing Specifications Insulation and Safety Related Specifications Package Characteristics Regulatory Information DIN V VDE V 0884-11 (VDE V 0884-11) Insulation Characteristics (Pending) Recommended Operating Conditions Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for ADuM4165/ADuM4166 ESD Caution Pin Configurations and Function Descriptions Truth Tables Typical Performance Characteristics Terminology Bus Upstream and Downstream Hub Host Peripheral Enumeration Low Speed Full Speed High Speed End of Packet (EOP) J State K State SE0 State SE1 State Idle L1 Suspend L2 Suspend Theory of Operation Automatic Data Transfer and Modes Retimer and Other Features Isolator Characteristics and Low Power Modes Applications Information Power Supply Options Clock Options PGOOD, Clock, and Power Sequencing Isolated USB Implementations Peripheral Applications Host Applications Interface Applications PCB Layout and Electromagnetic Interference (EMI) Insulation Lifetime Surface Tracking Insulation Wear Out Calculation and Use of Parameters Example Outline Dimensions Ordering Guide Evaluation Boards
