Datasheet MAX9075, MAX9077 (Maxim) - 4
ManufacturerMaxim
DescriptionLow-Cost, Ultra-Small, 3µA Single-Supply Comparators
Pages / Page9 / 4 — MAX9075/MAX9077. Low-Cost, Ultra-Small, 3µA Single-Supply Comparators. …
File Format / SizePDF / 141 Kb
MAX9075/MAX9077. Low-Cost, Ultra-Small, 3µA Single-Supply Comparators. Typical Operating Characteristics (continued)
MAX9075/MAX9077 Low-Cost, Ultra-Small, 3µA Single-Supply Comparators Typical Operating Characteristics (continued)
(VCC = 5V, VCM = 0V, 100mV overdrive, TA = +25°C, unless otherwise noted.)
SUPPLY CURRENT SUPPLY CURRENT INPUT OFFSET VOLTAGE vs. TEMPERATURE (OUT = LOW) vs. OUTPUT TRANSITION FREQUENCY vs. TEMPERATURE
4.0 1000 0 3.5 -0.1 MAX9075 toc10 MAX9075 toc11 MAX9075 toc12 3.0 -0.2 μA) VCC = 5V μA) 100 V 2.5 CC = 5V -0.3 VCC = 3V 2.0 -0.4 V V 1.5 CC = 2.1V CC = 3V -0.5 VCC = 5V 10 SUPPLY CURRENT ( SUPPLY CURRENT ( OFFSET VOLTAGE (mV) 1.0 V -0.6 CC = 3V VCC = 2.1V 0.5 VCC = 2.1V -0.7 0 1 -0.8 -55 -35 -15 5 25 45 65 85 1 10 100 1k 10k 100k 1M -55 -35 -15 5 25 45 65 85 TEMPERATURE (°C) TRANSITION FREQUENCY (Hz) TEMPERATURE (°C)
PROPAGATION DELAY PROPAGATION DELAY PROPAGATION DELAY vs. LOAD CAPACITANCE vs. INPUT OVERDRIVE (tPD+) vs. INPUT OVERDRIVE (tPD-)
0.7 1.6 0.7 tPD+ 0.6 1.4 0.6 MAX9075 toc13 MAX9075 toc14 MAX9075 toc15 μs) 1.2 μs) μs) 0.5 0.5 1.0 0.4 0.4 0.8 t V 0.3 PD- CC = 2.1V V 0.3 0.6 CC = 5V VCC = 3V VCC = 3V VCC = 5V 0.2 0.2 PROPAGATION DELAY ( PROPAGATION DELAY ( 0.4 PROPAGATION DELAY ( VCC = 2.1V 0.1 0.2 0.1 0 0 0 0 500 1000 1500 2000 0 50 100 150 200 250 0 50 100 150 200 250 LOAD CAPACITANCE (pF) INPUT OVERDRIVE (mV) INPUT OVERDRIVE (mV)
PROPAGATION DELAY PROPAGATION DELAY PROPAGATION DELAY vs. TEMPERATURE (VCC = 2.1V) vs. TEMPERATURE (VCC = 3V) vs. TEMPERATURE (VCC = 5V)
500 600 800 450 tPD+ 700 500 t 400 MAX9075 toc16 PD+ MAX9075 toc17 MAX9075 toc18 tPD+ 600 350 400 300 t 500 PD- 250 300 tPD- 400 200 300 200 tPD- 150 PROPAGATION DELAY (ns) PROPAGATION DELAY (ns) PROPAGATION DELAY (ns) 200 100 100 50 100 0 0 0 -55 -35 -15 5 25 45 65 85 -55 -35 -15 5 25 45 65 85 -55 -35 -15 5 25 45 65 85 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 4 Maxim Integrated
