Datasheet MC74VHC02 (ON Semiconductor) - 3
ManufacturerON Semiconductor
DescriptionQuad 2-Input NOR Gate
Pages / Page6 / 3 — MC74VHC02. MAXIMUM RATINGS. Symbol. Parameter. Value. Unit. RECOMMENDED …
File Format / SizePDF / 146 Kb
MC74VHC02. MAXIMUM RATINGS. Symbol. Parameter. Value. Unit. RECOMMENDED OPERATING CONDITIONS. Min. Max. DC ELECTRICAL CHARACTERISTICS
MC74VHC02 MAXIMUM RATINGS Symbol Parameter Value Unit RECOMMENDED OPERATING CONDITIONS Min Max DC ELECTRICAL CHARACTERISTICS
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
This device contains protection ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎ ÎÎÎ V circuitry to guard against damage CC DC Supply Voltage – 0.5 to + 7.0 V ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎ due to high static voltages or electric Vin DC Input Voltage – 0.5 to + 7.0 V fields. However, precautions must ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎ V be taken to avoid applications of any out DC Output Voltage – 0.5 to VCC + 0.5 V ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎ voltage higher than maximum rated IIK Input Diode Current − 20 mA voltages to this high−impedance cir- ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎ IOK Output Diode Current ± 20 mA cuit. For proper operation, Vin and ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎ V I out should be constrained to the out DC Output Current, per Pin ± 25 mA range GND v (Vin or Vout) v VCC. ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎ ICC DC Supply Current, VCC and GND Pins ± 50 mA Unused inputs must always be ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎ P ÎÎÎÎÎ tied to an appropriate logic voltage D Power Dissipation in Still Air, SOIC Packages† 500 mW TSSOP Package† 450 level (e.g., either GND or VCC). ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎ ÎÎÎ Unused outputs must be left open. Tstg Storage Temperature – 65 to + 150 C ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎ Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎ ÎÎÎ these limits are exceeded, device functionality should not be assumed, damage may occur and reliability may be affected. †Derating — SOIC Packages: – 7 mW/C from 65 to 125C TSSOP Package: − 6.1 mW/C from 65 to 125C
RECOMMENDED OPERATING CONDITIONS Symbol Parameter Min Max Unit
ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎ VCC DC Supply Voltage 2.0 5.5 V ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎ Vin DC Input Voltage 0 5.5 V ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎ Vout DC Output Voltage 0 VCC V ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎ TA Operating Temperature − 40 + 85 C ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎ tr, tf Input Rise and Fall Time VCC = 3.3V ±0.3V 0 100 ns/V ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ V ÎÎÎ ÎÎÎ ÎÎÎ CC =5.0V ±0.5V 0 20 ÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎ Functional operation above the stresses listed in the Recommended Operating Ranges is not implied. Extended exposure to stresses beyond the Recommended Operating Ranges limits may affect device reliability. ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
DC ELECTRICAL CHARACTERISTICS T T
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎÎ
V A = 25
C
ÎÎÎÎÎÎÎ
A = − 40 to 85
C
ÎÎ
CC V Min Typ Max Min Max
ÎÎÎÎ
Symbol
ÎÎÎÎÎÎÎÎ
Parameter
ÎÎÎÎÎÎÎ
Test Conditions
ÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎ
Unit
ÎÎÎÎ VIH Minimum High−Level Input 2.0 1.50 1.50 V ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎ ÎÎÎÎ Voltage 3.0 to VCC x 0.7 VCC x 0.7 ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎ 5.5 ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎÎ ÎÎ ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎÎ ÎÎ V ÎÎÎÎ IL Maximum Low−Level Input 2.0 0.50 0.50 V Voltage 3.0 to VCC x 0.3 VCC x 0.3 ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎÎ ÎÎ 5.5 ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎÎ ÎÎ ÎÎÎÎ VOH Minimum High−Level Output Vin = VIH or VIL 2.0 1.9 2.0 1.9 V ÎÎÎÎ ÎÎÎÎÎÎÎÎ Voltage ÎÎÎÎÎÎÎ IOH = − 50mA ÎÎÎ 3.0 ÎÎÎÎ 2.9 ÎÎÎ 3.0 ÎÎÎ ÎÎÎÎ 2.9 ÎÎÎÎ ÎÎ 4.5 4.4 4.5 4.4 ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎÎ ÎÎ Vin = VIH or VIL ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎÎ ÎÎ ÎÎÎÎ IOH = − 4mA 3.0 2.58 2.48 I 4.5 3.94 3.80 ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎ OH = − 8mA ÎÎÎÎ VOL Maximum Low−Level Output Vin = VIH or VIL 2.0 0.0 0.1 0.1 V ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎ ÎÎÎÎ Voltage IOL = 50mA 3.0 0.0 0.1 0.1 ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎ 4.5 ÎÎÎÎ ÎÎÎ 0.0 ÎÎÎ 0.1 ÎÎÎÎ ÎÎÎÎ 0.1 ÎÎ ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎÎ ÎÎ V ÎÎÎÎ in = VIH or VIL IOL = 4mA 3.0 0.36 0.44 ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎ ÎÎÎÎ IOL = 8mA 4.5 0.36 0.44 ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎ ÎÎÎÎ Iin Maximum Input Leakage Vin = 5.5 V or GND 0 to 5.5 ± 0.1 ± 1.0 mA ÎÎÎÎ ÎÎÎÎÎÎÎÎ Current ÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎÎ ÎÎ I Maximum Quiescent Supply V 5.5 2.0 20.0 mA ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎÎ ÎÎ CC ÎÎÎÎÎÎÎÎ in = VCC or GND ÎÎÎ ÎÎÎÎ Current ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎÎ ÎÎ Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product ÎÎÎÎ ÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎÎ ÎÎ performance may not be indicated by the Electrical Characteristics if operated under different conditions.
www.onsemi.com 2
