Datasheet MBRS2040 (ON Semiconductor)
Manufacturer | ON Semiconductor |
Description | Surface Mount Schottky Power Rectifier SMB Power Surface Mount Package |
Pages / Page | 6 / 1 — SMB Power Surface Mount Package. www.onsemi.com. SCHOTTKY BARRIER. … |
File Format / Size | PDF / 310 Kb |
SMB Power Surface Mount Package. www.onsemi.com. SCHOTTKY BARRIER. RECTIFIER. 2.0 AMPERES. 40 VOLTS. Features. SMB. CASE 403A
MBRS2040LT3G, NRVBS2040LT3G, NRVBS2040LN
www.onsemi.com
. employing the Schottky Barrier principle in a metal−to−silicon
SCHOTTKY BARRIER
power rectifier. Features epitaxial construction with oxide passivation
RECTIFIER
and metal overlay contact. Ideally suited for low voltage, high frequency switching power supplies; free wheeling diodes and
2.0 AMPERES
polarity protection diodes.
40 VOLTS Features
• Compact Package with J−Bend Leads Ideal for Automated Handling • Highly Stable Oxide Passivated Junction • Guardring for Over−Voltage Protection • Low Forward Voltage Drop
SMB CASE 403A
• ESD Ratings: ♦ Human Body Model = 3B (> 16000 V) ♦ Machine Model = C (> 400 V)
MARKING DIAGRAM
• NRVB Prefix for Automotive and Other Applications Requiring Unique Site and Control Change Requirements; AEC−Q101 AYWW BKJLG Qualified and PPAP Capable* G • These are Pb−Free Devices
Mechanical Characteristics
BKJL = Specific Device Code • A = Assembly Location** Case: Molded Epoxy Y = Year • Epoxy Meets UL94, VO at 1/8″ WW = Work Week • Weight: 95 mg (approximately) G = Pb−Free Package • Maximum Temperature of 260°C / 10 Seconds for Soldering (Note: Microdot may be in either location) • Cathode Polarity Band • Available in 12 mm Tape, 2500 Units per 13 inch Reel, Add “T3” **The Assembly Location code (A) is front side optional. In cases where the Assembly Location is Suffix to Part Number stamped in the package bottom (molding ejecter pin), • Finish: All External Surfaces Corrosion Resistant and Terminal the front side assembly code may be blank. Leads are Readily Solderable • Marking: BKJL
ORDERING INFORMATION Device Package Shipping
† MBRS2040LT3G SMB 2,500 / (Pb−Free) Tape & Reel NRVBS2040LT3G* SMB 2,500 / (Pb−Free) Tape & Reel NRVBS2040LNT3G* SMB 2,500 / (Pb−Free) Tape & Reel †For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specifications Brochure, BRD8011/D. © Semiconductor Components Industries, LLC, 2012
1
Publication Order Number:
December, 2019 − Rev. 6 MBRS2040LT3/D
