Datasheet MBRS2040 (ON Semiconductor) - 3
ManufacturerON Semiconductor
DescriptionSurface Mount Schottky Power Rectifier SMB Power Surface Mount Package
Pages / Page6 / 3 — MBRS2040LT3G, NRVBS2040LT3G, NRVBS2040LN. TYPICAL CHARACTERISTICS. Figure …
File Format / SizePDF / 310 Kb
MBRS2040LT3G, NRVBS2040LT3G, NRVBS2040LN. TYPICAL CHARACTERISTICS. Figure 1. Typical Forward Voltage
MBRS2040LT3G, NRVBS2040LT3G, NRVBS2040LN TYPICAL CHARACTERISTICS Figure 1 Typical Forward Voltage
100 100 100 (AMPS) (AMPS) 10 10 ARD CURRENT ARD CURRENT W W TJ = 125°C TJ = 25°C T 1.0 J = 100°C T 1.0 J = 25°C T ANEOUS FOR ANEOUS FOR J = 100°C TJ = 125°C ANT ANT TJ = -40°C 0.1 0.1 , INST , INST i F 0 0.2 0.4 0.6 0.8 I F 0 0.2 0.4 0.6 0.8 vF, INSTANTANEOUS FORWARD VOLTAGE (VOLTS) VF, MAXIMUM INSTANTANEOUS FORWARD VOLTAGE (VOLTS)
Figure 1. Typical Forward Voltage Figure 2. Maximum Forward Voltage
100E-3 100E-3 TJ = 125°C 10E-3 (AMPS) 10E-3 TJ = 125°C T (AMPS) J = 100°C 1.0E-3 TJ = 100°C 1.0E-3 100E-6 100E-6 TJ = 25°C , REVERSE CURRENT 10E-6 TJ = 25°C 10E-6 I R , MAXIMUM REVERSE CURRENT I R 1.0E-6 1.0E-6 0 10 20 30 40 0 10 20 30 VR, REVERSE VOLTAGE (VOLTS) VR V , REVERSE VOLTAGE (VOLTS) R, REVERSE VOLTAGE (VOL 40
Figure 3. Typical Reverse Current Figure 4. Maximum Reverse Current
3.5 1.2 dc TTS) A SQUARE WAVE 3.0 1.0 (AMPS) Ipk/Io = p dc 2.5 TION (W A SQUARE WAVE 0.8 CURRENT I 2.0 pk/Io = 5 Ipk/Io = p 0.6 ARD W 1.5 Ipk/Io = 10 Ipk/Io = 5 FOR 0.4 1.0 I I pk/Io = 10 pk/Io = 20 I VERAGE pk/Io = 20 VERAGE POWER DISSIP 0.5 0.2 , A , A I O FO 0 P 0 0 20 40 60 80 100 120 140 0 0.5 1.0 1.5 2.0 2.5 TL, LEAD TEMPERATURE (°C) IO, AVERAGE FORWARD CURRENT (AMPS)
Figure 5. Current Derating Figure 6. Forward Power Dissipation
3.0
www.onsemi.com 3
