Datasheet MOS6020 (Coilcraft)
ManufacturerCoilcraft
DescriptionShielded Power Inductors
Pages / Page2 / 1 — Shielded Power Inductors – MOS6020. Designer’s Kit C359. Core material. …
File Format / SizePDF / 236 Kb
Shielded Power Inductors – MOS6020. Designer’s Kit C359. Core material. Core and winding loss. Terminations. Weight
Datasheet MOS6020 Coilcraft
Web Sample Tools & Support page & buy software & FAQ Document 287 -1
AEC • 6.0 × 7.1 mm footprint; 2.4 mm high shielded inductors Q200 85 + °C • Custom versions up to 4.7 mH are available.
Designer’s Kit C359
contains 3 of each value
Core material
Ferrite
See www.coilcraft.com/coreloss
Terminations
RoHS compliant matte tin over nickel over phos bronze. Other terminations available at additional cost.
Weight
0.21 g
Ambient temperature
–40°C to +85°C with (40°C rise) Irms current.
Maximum part temperature
+125°C (ambient + temp rise). Derating.
Storage temperature
Component: –40°C to +125°C. Tape and reel packaging: –40°C to +80°C
Resistance to soldering heat
Max three 40 second reflows at +260°C, parts cooled to room temperature between cycles
Moisture Sensitivity Level (MSL)
1 (unlimited floor life at <30°C / 85% relative humidity)
Packaging
500 per 7″ reel; 2000 per 13″ reel; Plastic tape: 16 mm wide, 0.3 mm thick, 12 mm pocket spacing, 2.5 mm pocket depth
PCB washing
Tested to MIL-STD-202 Method 215 plus an additional aqueous wash. See Doc787_PCB_Washing.pdf.
Inductance
2
DCR max SRF typ
3
2 Isat (A)
4
Irms (A)
5
Part number
1
±20% (µH) (Ohms) (MHz) 10% drop 20% drop 30% drop 20°C rise 40°C rise
MOS6020-222ML_ 2.2 0.035 110 2.86 3.26 3.56 3.0 4.1 MOS6020-332ML_ 3.3 0.046 85 1.90 2.28 2.46 2.6 3.6 MOS6020-472ML_ 4.7 0.050 60 1.46 1.82 1.94 2.3 3.1 MOS6020-682ML_ 6.8 0.078 55 1.32 1.56 1.72 1.9 2.7 MOS6020-822ML_ 8.2 0.085 45 0.94 1.18 1.30 1.7 2.3 MOS6020-103ML_ 10 0.092 36 0.79 0.95 1.06 1.6 2.2 MOS6020-153ML_ 15 0.130 30 0.83 0.95 1.03 1.3 1.8 MOS6020-223ML_ 22 0.182 22 0.79 0.92 0.97 1.0 1.4 MOS6020-333ML_ 33 0.290 20 0.57 0.67 0.74 0.80 1.1 MOS6020-473ML_ 47 0.420 16 0.45 0.56 0.62 0.50 0.7 MOS6020-683ML_ 68 0.520 15 0.37 0.45 0.51 0.45 0.63 MOS6020-104ML_ 100 0.800 13 0.35 0.40 0.44 0.40 0.56 MOS6020-154ML_ 150 1.28 10 0.26 0.30 0.33 0.35 0.49 MOS6020-224ML_ 220 2.00 8 0.22 0.26 0.28 0.30 0.42 MOS6020-334ML_ 330 2.84 7 0.18 0.22 0.24 0.25 0.35 MOS6020-474ML_ 470 4.40 5 0.15 0.17 0.19 0.22 0.29 1. When ordering, please specify
termination
and
packaging
codes: 2. Inductance tested at 100 kHz, 0.1 Vrms, 0 Adc using an Agilent/ HP 4263B LCR meter or equivalent.
MOS6020-104MLC
3. SRF measured using Agilent/HP 8753D network analyzer.
Termination: L
= RoHS compliant mat e tin over nickel over phos bronze. 4. DC current at 25°C that causes the specified inductance drop from its Special order:
T
= RoHS tin-silver-copper (95.5/4/0.5) value without current. Click for temperature derating information. or
S
= non-RoHS tin-lead (63/37). 5. Current that causes the specified temperature rise from 25°C ambient.
Packaging: C
= 7″ machine-ready reel. EIA-481 embossed plastic This information is for reference only and does not represent absolute tape (500 parts per full reel). Quantities less than maximum ratings. Click for temperature derating information. full reel available: in tape (not machine ready) or with 6. Electrical specifications at 25°C. leader and trailer ($25 charge). Refer to Doc 362 “Soldering Surface Mount Components” before soldering.
D
= 13″ machine-ready reel. EIA-481 embossed plastic tape. Factory order, not stocked (2000 parts per reel).
B
= Less than full reel. In an effort to simplify our part numbering system, Coilcraft is eliminating the need for multiple packaging codes. When ordering, simply change the last letter of your part number from B to C.
US
+1-847-639-6400 sales@coilcraft.com Document 287-1 Revised 10/31/22
UK
+44-1236-730595 sales@coilcraft-europe.com © Coilcraft Inc. 2022
Taiwan
+886-2-2264 3646 sales@coilcraft.com.tw This product may not be used in medical or high
China
+86-21-6218 8074 sales@coilcraft.com.cn risk applications without prior Coilcraft approval. Specification subject to change without notice.
Singapore
+ 65-6484 8412 sales@coilcraft.com.sg Please check web site for latest information.
