Datasheet LF155, LF156, LF256, LF257 LF355, LF356, LF357 (Texas Instruments) - 9
ManufacturerTexas Instruments
DescriptionLFx5x J FET Input Operational Amplifiers
Pages / Page46 / 9 — LF155, LF156. , LF256. , LF257. LF355, LF356. , LF357. www.ti.com. …
File Format / SizePDF / 2.7 Mb
LF155, LF156. , LF256. , LF257. LF355, LF356. , LF357. www.ti.com. Typical DC Performance Characteristics (continued)
LF155, LF156 , LF256 , LF257 LF355, LF356 , LF357 www.ti.com Typical DC Performance Characteristics (continued)
SNOSBH0D – MAY 2000 – REVISED NOVEMBER 2015
Curves are for LF155 and LF156 unless otherwise specified.
Figure 8. Positive Current Limit Figure 7. Negative Current Limit Figure 9. Positive Common-Mode Input Voltage Limit Figure 10. Negative Common-Mode Input Voltage Limit Figure 11. Open-Loop Voltage Gain Figure 12. Output Voltage Swing
Copyright © 2000–2015, Texas Instruments Incorporated Submit Documentation Feedback 9 LF156 LF256 LF356 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 AC Electrical Characteristics, TA = TJ = 25°C, VS = ±15 V 6.6 DC Electrical Characteristics, TA = TJ = 25°C, VS = ±15 V 6.7 DC Electrical Characteristics 6.8 Power Dissipation Ratings 6.9 Typical Characteristics 6.9.1 Typical DC Performance Characteristics 6.9.2 Typical AC Performance Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Large Differential Input Voltage 7.3.2 Large Common-Mode Input Voltage 7.4 Device Functional Modes 8 Application and Implementation 8.1 Application Information 8.2 Typical Application 8.2.1 Design Requirements 8.2.2 Detailed Design Procedure 8.2.3 Application Curves 8.3 System Examples 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.1.1 Printed-Circuit-Board Layout For High-Impedance Work 10.2 Layout Example 11 Device and Documentation Support 11.1 Related Links 11.2 Community Resources 11.3 Trademarks 11.4 Electrostatic Discharge Caution 11.5 Glossary 12 Mechanical, Packaging, and Orderable Information
