TS271Electrical Characteristics3 Electrical CharacteristicsTable 3.for I+-SET = 1.5µA - VCC = +10V, VCC = 0V, Tamb = +25°C (unless otherwise specified)TS271I/AI/BITS271C/AC/BCSymbolParameterTS271M/AM/BMUnitMin.Typ.Max.Min.Typ.Max. Input Offset Voltage VO = 1.4V, Vic = 0V TS271C/I/M 1.1 10 10 1.1 TS271AC/AI/AM 0.9 5 5 0.9 Vio TS271BC/BI/BM 0.25 2 2 mV 0.25 Tmin ≤ Tamb ≤ Tmax TS271C/I/M 12 12 TS271AC/AI/AM 6.5 6.5 TS271BC/BI/BM 3 3.5 DVio Input Offset Voltage Drift 2 2 µV/°C Input Offset Current note 1 Iio Vic = 5V, VO = 5V 1 1 pA T 100 200 min ≤ Tamb ≤ Tmax Input Bias Current - see note 1 Iib Vic = 5V, VO = 5V 1 1 pA T 150 300 min ≤ Tamb ≤ Tmax High Level Output Voltage V V OH id = 100mV, RL = 1MΩ 8.8 9 8.8 9 V Tmin ≤ Tamb ≤ Tmax 8.7 8.6 Low Level Output Voltage VOL mV Vid = -100mV 50 50 Large Signal Voltage Gain A V vd iC = 5V, RL = 1MΩ, Vo = 1V to 6V 30 100 30 100 V/mV Tmin ≤ Tamb ≤ Tmax 20 20 Gain Bandwidth Product GBP MHz Av = 40dB, RL = 1MΩ, CL = 100pF, fin = 100kHz 0.1 0.1 Common Mode Rejection Ratio CMR dB ViC = 1V to 7.4V, Vo = 1.4V 60 80 60 80 Supply Voltage Rejection Ratio SVR dB V + CC = 5V to 10V, Vo = 1.4V 60 80 60 80 Supply Current (per amplifier) I A CC v = 1, no load, Vo = 5V 10 15 10 15 µA Tmin ≤ Tamb ≤ Tmax 17 18 Output Short Circuit Current Io mA Vo = 0V, Vid = 100mV 60 60 Output Sink Current Isink mA Vo = VCC, Vid = -100mV 45 45 Slew Rate at Unity Gain SR V/µs RL = 1MΩ, CL = 100pF, Vi = 3 to 7V 0.04 0.04 Phase Margin at Unity Gain φm Av = 40dB, RL = 1MΩ CL = 10pF 35 35 Degrees CL = 100pF 10 10 Overshoot Factor K A OV v = 40dB, RL = 1MΩ CL = 10pF 40 40 % CL = 100pF 70 70 Equivalent Input Noise Voltage nV en f = 1kHz, R ------ s = 100Ω 30 30 Hz 1) Maximum values including unavoidable inaccuracies of the industrial test. 6/17 Document Outline 1 Block Diagram 2 Absolute Maximum Ratings 3 Electrical Characteristics 4 Electrical Characteristics 5 Electrical Characteristics 6 Package Mechanical Data 7 Revision History
