Datasheet MBR2030CTLG (ON Semiconductor) - 3
ManufacturerON Semiconductor
DescriptionSwitch-mode Dual Schottky Power Rectifier
Pages / Page6 / 3 — MBR2030CTLG. Figure 1. Typical Forward Voltage. Figure 2. Maximum Forward …
File Format / SizePDF / 243 Kb
MBR2030CTLG. Figure 1. Typical Forward Voltage. Figure 2. Maximum Forward Voltage. Figure 3. Typical Reverse Current
MBR2030CTLG Figure 1 Typical Forward Voltage Figure 2 Maximum Forward Voltage Figure 3 Typical Reverse Current
MBR2030CTLG
100 100 (AMPS) (AMPS) TJ = 175°C TJ = 175°C 10 10 150°C ARD CURRENT ARD CURRENT 100 150 °C W 100°C W °C 25°C 25°C 1.0 1.0 ANEOUS FOR ANEOUS FOR ANT ANT 0.1 0.1 i , INST F F 0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 i , INST 0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 vF, INSTANTANEOUS FORWARD VOLTAGE (VOLTS) vF, INSTANTANEOUS FORWARD VOLTAGE (VOLTS)
Figure 1. Typical Forward Voltage Figure 2. Maximum Forward Voltage
10000 20 4000 2000 18 (AMPS) 1000 dc 16 (mA) 400 200 14 100 TJ = 150°C 12 40 SQUARE WAVE 20 ARD CURRENT W 10 10 TJ = 100°C 4 8.0 2 1 6.0 0.4 I , REVERSE CURRENT R 0.2 VERAGE FOR 4.0 A 0.1 V) 2.0 0.04 TJ = 25°C 0.02 I , F (A 0.01 0 0 5 10 15 20 25 30 140 145 150 155 160 165 170 175 180 VR REVERSE VOLTAGE (VOLTS) TC, CASE TEMPERATURE (C°)
Figure 3. Typical Reverse Current Figure 4. Current Derating, Case Per Leg
20 TTS) A 30 RATED VOLTAGE APPLIED 28 18 TJ = 175°C (AMPS) 26 dc R 16 qJA = 16° C/W TION (W 24 R A qJA = 60° C/W 22 SQUARE WAVE 14 (NO HEATSINK) 20 12 18 ARD CURRENT 16 W 10 SQUARE WAVE dc 14 8.0 12 dc ARD POWER DISSIP 10 6.0 W 8 VERAGE FOR 4.0 6 A 4 V) 2.0 2 I , F (A 0 VERAGE FOR 0 0 25 50 75 100 125 150 175 A 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 V) I T F(AV), AVERAGE FORWARD CURRENT (AMPS) A, AMBIENT TEMPERATURE (°C) , P F (A
Figure 5. Current Derating, Ambient Per Leg Figure 6. Forward Power Dissipation www.onsemi.com 3
