Datasheet MBR2030CTLG (ON Semiconductor) - 5
Manufacturer | ON Semiconductor |
Description | Switch-mode Dual Schottky Power Rectifier |
Pages / Page | 6 / 5 — PACKAGE DIMENSIONS. TO−220. SCALE 1:1. DOCUMENT NUMBER: 98ASB42148B. … |
File Format / Size | PDF / 243 Kb |
PACKAGE DIMENSIONS. TO−220. SCALE 1:1. DOCUMENT NUMBER: 98ASB42148B. DESCRIPTION:. PAGE 1 OF 1. onsemi
MECHANICAL CASE OUTLINE
PACKAGE DIMENSIONS TO−220
CASE 221A ISSUE AK DATE 13 JAN 2022
SCALE 1:1
STYLE 1: STYLE 2: STYLE 3: STYLE 4: PIN 1. BASE PIN 1. BASE PIN 1. CATHODE PIN 1. MAIN TERMINAL 1 2. COLLECTOR 2. EMITTER 2. ANODE 2. MAIN TERMINAL 2 3. EMITTER 3. COLLECTOR 3. GATE 3. GATE 4. COLLECTOR 4. EMITTER 4. ANODE 4. MAIN TERMINAL 2 STYLE 5: STYLE 6: STYLE 7: STYLE 8: PIN 1. GATE PIN 1. ANODE PIN 1. CATHODE PIN 1. CATHODE 2. DRAIN 2. CATHODE 2. ANODE 2. ANODE 3. SOURCE 3. ANODE 3. CATHODE 3. EXTERNAL TRIP/DELAY 4. DRAIN 4. CATHODE 4. ANODE 4. ANODE STYLE 9: STYLE 10: STYLE 11: STYLE 12: PIN 1. GATE PIN 1. GATE PIN 1. DRAIN PIN 1. MAIN TERMINAL 1 2. COLLECTOR 2. SOURCE 2. SOURCE 2. MAIN TERMINAL 2 3. EMITTER 3. DRAIN 3. GATE 3. GATE 4. COLLECTOR 4. SOURCE 4. SOURCE 4. NOT CONNECTED
Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red.
DESCRIPTION: TO−220 PAGE 1 OF 1 onsemi
and are trademarks of Semiconductor Components Industries, LLC dba
onsemi
or its subsidiaries in the United States and/or other countries.
onsemi
reserves the right to make changes without further notice to any products herein.
onsemi
makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does
onsemi
assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages.
onsemi
does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2019 www.onsemi.com
