LT1110 WUTYPICAL PERFOR A CE CHAR CA TERISTICSSet Pin Bias CurrentFB Pin Bias CurrentReference Voltage 160 120 226 110 140 224 100 120 90 222 80 100 70 220 80 60 (mV) REF 50 V 218 60 40 BIAS CURRENT (nA) BIAS CURRENT (nA) 216 40 30 20 20 214 10 0 0 212 –50 –25 0 25 50 75 100 –50 –25 0 25 50 75 100 –50 –25 0 25 50 75 100 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) LT1110 • TPC13 LT1110 • TPC14 LT1110 • TPC15 UUOUPIFU CTISILIM (Pin 1): Connect this pin to VIN for normal use. Where GND (Pin 5): Ground. lower current limit is desired, connect a resistor between AO (Pin 6): Auxiliary Gain Block (GB) output. Open collector, ILIM and VIN. A 220Ω resistor will limit the switch current can sink 300µA. to approximately 400mA. SET (Pin 7): GB input. GB is an op amp with positive input VIN (Pin 2): Input supply voltage. connected to SET pin and negative input connected to SW1 (Pin 3): Collector of power transistor. For step-up 220mV reference. mode connect to inductor/diode. For step-down mode FB/SENSE (Pin 8): On the LT1110 (adjustable) this pin connect to VIN. goes to the comparator input. On the LT1110-5 and SW2 (Pin 4): Emitter of power transistor. For step-up LT1110-12, this pin goes to the internal application resistor mode connect to ground. For step-down mode connect to that sets output voltage. inductor/diode. This pin must never be allowed to go more than a Schottky diode drop below ground. WLT1110 BLOCKID AGRA SET + A2 AO – VIN GAIN BLOCK/ERROR AMP ILIM SW1 220mV REFERENCE A1 OSCILLATOR Q1 DRIVER COMPARATOR GND SW2 FB LT1110 • BD01 5
